Zoom lens
Discussion in 'Sony Chat' started by Bulldog, Jan 24, 2004.
  1. Bulldog
    Bulldog Well-Known Member
    Originally tried this in Help Team forum without response. The lens is for Dynax 800si. I'm currently using a Minolta 28-80 which was originally obtained as part of a dynax 500si kit, but I'm not too happy with the results and I get vignetting at the wide end when using filters, even with thin proffesional ones. Original post:
    "I'm looking to buy a high quality zoom 24/28 to 70/80mm. I quite like the look of the new Tamron 28-75mm f2.8. Does anyone have any others they can recommend to fit Minolta AF? I'm willing to buy new or good condition used up to £300."
    Cheers
    Chris [​IMG]
  2. RonM
    RonM Alpha Napper
    Chris,
    I've no personal experience with the fast zooms you are looking at, I've done some searching about on a couple of Minolta forums I'm a member of, but, the consensus seems to be that Minoltas own lenses are better than the likes of Sigma, Tamron and Tokina.
    I have however, seen coments on the Tokina 28-80 f/2.8 AT-X Pro which seemed to rate this lens quite highly (I must admit to being tempted) and found this report 28-80 f/2.8 AT-X hope this sort of helps.
    <font color=blue>RonM CRIPN</font color=blue>
    Everyone has a photographic memory. Some just don't have film.
  3. huwevans
    huwevans Not Really Here
    As Ron says, the Minolta's own lenses will probably be the best if you can find the money for them. But to add to the recommendation for the Tokina AT-X Pro 28-80, I have one and it is certainly very well made and sharp. Flare is a problem if you get the sun or other strong light source in view, but aside from this I've no real criticisms of it.
    Huw Evans.
    www.huwevans.freeuk.com
  4. Bulldog
    Thanks guys, looks like the Tokina is worth checking out. My current Minolta lens flares badly so i'm used to allowing for that already.
    Cheers
    Chris [​IMG]
  5. oddjob
    oddjob Active Member
    Hi Chris
    Just thought I'd add to the recommendations of the Tokina 28-80. I've used one for about 18mths now teamed up with an 800si, bought mint secondhand from ffordes and its been superb.
    Can't remember exactly how much I paid but it was around the £250 mark.
    Cheers
    Ian
    OJ
  6. Bulldog
    Thanks Ian,
    I've checked out the spec on the ATX Pro and it's now top of my shopping list /img/wwwthreads/smile.gif
    Cheers
    Chris [​IMG]
