World Pinhole Day
Discussion in 'Everything Film' started by steveandthedogs, Apr 18, 2020.
  1. gray1720
    gray1720 Well-Known Member
    Well, the damn Zoom took up a lot of the arvo, and I completely lost the thread of what I was planning to do...
    However, I did get a couple of cyanotypes in - currently flattening twixt the volumes of an 1880s Chambers Encyclopedia - and excavated the FrankenPinLeica. I really must put some effort into working out the gubbins to give me half a clue as to the exposures, though, as winging it without a clue is a recipe for disappointment. IMG_6508.jpg
    Zou and steveandthedogs like this.
  2. steveandthedogs
    Try :
    http://www.mrpinhole.com/calcpinh.php
  3. gray1720
    Interesting - I reckon my pinhole (just to be anal, it really was made with a pin) is about 0.2mm (see pic, measure it up yourselves if you want to check!) and according to Mr Pinhole* my sunny day exposure with ISO100 film is half a second - I'm really surprised it's that short from such a tiny opening. I've been going waaay over that. Annoyingly the FrankenPinLeica doesn't have the film plane marked on it, but I reckon I have my focal length in the right ballpark and, as far as I can see, it affects the angle of view more than exposure time.
    *I do hope Mr Pinhole is not related in anny way to Mr Pin!
    steveandthedogs and Zou like this.
  4. gray1720
    ...and here's the cyanotypes. I did one with a geranium leaf, and one with one of my glass plate negs - that one is OK, but I really, really like the leaf.
    Zou likes this.
  5. Zou
    I found the easiest way to measure the pinhole was to scan it at very high res next to the rule; far easier to estimate than zooming in on a photo. Your 1/2s doesn't sound unreasonable to me; sunny conditions really make a difference compared to other brightish days.
  6. gray1720
    That's a good idea - now, can I unearth my scanner? It's been relegated to make space for the work computer...
  7. steveandthedogs
    Ain't that the truth.
    Aperture .2mm, focal length ?35mm - ish so f = 35/0.2 =175, so 1/2 -3/4 sec about right, but don't forget reciprocity add-on.
    Which film? 1/2s is spot-on for FP4+ according to PinholeDesigner. Ditto Foma 100, but more than 1/2s, Foma 100 goes berserk and needs about three weeks.
    Like the cyanotypes. Wish I could get them to work...
    S
  8. gray1720
    Neopan 100 - I can see a film order may distract me from saving for a shed, especially after buying four more box cameras, and even more especially as I am out of fixer! Thanks for the warning on Foma, it's just the stuff I'd try too.
    Any idea where I could find some red plastic to patch a missing window?
  9. steveandthedogs
    Don't think Neopan has any recip failure.
    Pinhole camera exposure times :
    f number: 175
    Including reciprocity failure for film: Fomapan 100
    For Fomapan 100:
    Time for f 22 Resulting time
    1/1000 1/15
    1/500 1/8
    1/250 1/4
    1/125 1/2
    1/60 2 s
    1/30 11 s
    1/15 28 s
    1/8 1 m
    1/4 2 m
    1/2 5 m
    1 s 14 m
    2 s 38 m
    4 s 2 h
    8 s 7 h
    15 s 23 h
    30 s 87 h
    1 m 341 h
    2 m 1346 h
    Created by PinholeDesigner 2.0, film database v1 (9. 6. 2003)
    Copyright © David Balihar, 2001-2003
    As for the red plastic thing, what about a bit of clear plastic stuck on the inside and painted with red glass paint? I've used this in the past :
    https://www.therange.co.uk/arts-and...ste-aquaglass-transparent-glass-paint/#463658
    S
  10. Zou
    IIRC Neopan is ok down to 2 minutes and thereafter rf kicks in. Take that with a huge pinch of salt though as it's about 15 years since I last used it and my memory could be foggy.
    Edit to add:
    Just checked it. Remarkably my memory was correct! :D
    steveandthedogs likes this.
  11. steveandthedogs
    Just a touch better than Fomapan, then.
    S
  12. gray1720
    You weren't kidding about the Fomapan! Bloomin' flip!
