What grinds your gears?
Discussion in 'The Lounge' started by retrofit, Nov 20, 2016.
  1. Andrew Flannigan
    Just out of interest, how many people will admit to losing concentration for a moment and forgetting to signal? I've done it.
  2. Dorset_Mike
    Dorset_Mike Grumpy Old Fart
    I seem to be at the other end of the scale, I indicate regardless of if there is anyone behind to see the signal.
    AndyTake2, peterba, Footloose and 2 others like this.
  3. Benchista
    Lost concentration whist in the process of manoeuvering? Can't say I have, no.
  4. AlanW
    AlanW Well-Known Member
    Indicators are not just to alert other drivers, as a pedestrian most of the time (when I'm not on the bus) I find it really annoying when drivers turn onto a road I'm about to cross without any indication :(
  5. Benchista
    Yup. They're for other road users, no matter what form that road usage takes.
    Trannifan, peterba and Roger Hicks like this.
  6. PhotoEcosse
    PhotoEcosse Well-Known Member
    Me too.
    Another thing that annoys me, particularly in darkness at night, is the driver who does not know he/she has a handbrake and sits with his/her foot on the footbrake while waiting at traffic lights or road junctions, dazzling the driver behind with the glare of high intensity brakelights. Morons.
  7. Catriona
    Catriona Well-Known Member
    I so agree! I'm afraid I 'indicate' my disapproval to them as I jump backwards!
  8. DaveS
    DaveS Well-Known Member
    I always try to indicate when leaving a roundabout, the "try" bit is because my indicator switch is getting a bit worn and will cancel at the slightest course correction, often leaving no time to re-indicate before needing both hands on the wheel for the turn. Unless, of course, you're one of those drivers who only use one hand on the wheel.
  9. Gezza
    Gezza Well-Known Member
    You only need one hand for the steering wheel... the other one is for you fag or phone...Isn't it?
  10. Footloose
    Footloose Well-Known Member
    Having ridden motorcycles for decades, indicating is an almost instinctive action.
    What slightly irritates me, are drivers waiting at traffic lights who (on level ground) engage the handbrake, put the car in neutral but don't watch the traffic lights or brake lights of the 1 or 2 vehicles ahead of them, so that as a consequence, 3 or 4 fewer vehicles then get through the lights once they have changed.
    In some countries, (eg France?) there is a secondary smaller set of lights about a metre above the ground. Presumably, these are so that those right next to the lights, know the larger lights have changed, but can't see they have, because of the pillars and rooflines on cars.
    Somewhat more 'interesting', is that in some Asian countries the traffic lights have a countdown function, great for their impatient drivers, but probably hair-raising for some pedestrians!
  11. Roger Hicks
    With very few exceptions (Austin A35 and one early Land Rover spring to mind), all the vehicles I have ever driven have allowed me to operate the indicator stalk with both hands on the steering wheel.
    PhotoEcosse and Andrew Flannigan like this.
  12. Roger Hicks
    Not just in Asia: I have encountered this in several European countries too. Not at all lights, but at some.
  13. GeoffR
    Same for me.
  14. GeoffR
    Before you judge the driver be aware that Jaguar have designed their "Eco Stop/Start" system to shut the engine down when the vehicle stops and to restart when the brakes are released. Using the park brake, and thus releasing the foot brakes, results in the engine restarting. Yes it is a poor design. The fact that the Highway Code suggests that this is poor practice is ignored.
  15. DaveS
    Oh sure, I can operate the indicators with the little finger of my left hand, it's just that they sometimes cancel as I'm turning for the exit.
    Some pedestrian lights here have a countdown on amber to show how long you've got. Varies from 5-10 sec depending on the set.
  16. GeoffR
    On the subject of roads, I get really annoyed by road works, with temporary traffic lights, where I get held up only to reach the site and find nobody actually doing any work. If your works are going to cause disruption you really need to be working 24/7 to get them completed. Obviously only where that is legal.
  17. LesleySM
    LesleySM Well-Known Member
    Countdown's on pelican crossings to help pedestrians know how much longer they have are commonplace around my way- they were installed when the Olympics came to town and every time a crossing gets upgraded they're put in
  18. PhotoEcosse
    Are you sure, Geoff?
    My engine cuts out when I stop (unless I am using a lot of electrical equipment such as demisters, blowers,etc.). But it is not releasing the brake that re-starts the engine; it is depresing the clutch pedal to move into gear.
  19. PhotoEcosse
    Didn't the A35 have the indicator switch on the central boss of the steering wheel? I suppose that counts as taking one hand off the rim of the wheel to use it.
    With several older cars I retro-fitted (horrible term) flashing indicators to replace trafficator arms. I had to fit the switch on the dash, thus necessitating removing a hand from the wheel to indicate but, on the other hand, they were not self-cancelling, so avoided the problem experienced by DaveS.
    Also bear in mind that, in the days when I passed my driving test (and I assume Roger H), a compulsory component of the test was sticking one's arm out of an open window to give hand signals for turning and for slowing down, so removing a hand from the wheel was obligatory.
  20. GeoffR
    Absolutely sure! The Jaguar XF, until the 2016 model, wasn't available with a clutch and even now manual models of the XE and XF are rare with none available for the XJ.
