What grinds your gears?
Discussion in 'The Lounge' started by retrofit, Nov 20, 2016.
  1. dangie
    dangie Senior Knobhead
    And me. But I have a dilemma. I'm hoping to go out for a bike ride. Looking out the back window it's fairly bright. Looking out the front window it's dull. Now do I go towards the bright and hope it doesn't go dull, or do I go towards the dull and hope it goes bright? Problem....
  2. MickLL
    MickLL Well-Known Member
    When I look out of the window I try to judge which way the wind is blowing (pretty easy for me with all the trees around) and that gives me a lot of information.
    MickLL
  3. spinno
    One always has to be careful heading for the light, as it may be a one way journey
  4. RovingMike
    In the Surrey Hills, that can result in a real soaking. It changes so fast and as the air rises to where we are, it drops its lot.
  5. RovingMike
    There are things you can do to make sure it won't rain: take an umbrella, don't wash the car....
    spinno likes this.
  6. daft_biker
    daft_biker Action Man!
    @GeoffR crunch, crunch from the back over the first couple of speed bumps this morning then felt funny....
  7. GeoffR
    Ouch! Might as well replace the dampers at the same time! Unless they are fairly new.
  8. Andrew Flannigan
    I once worked with a programmer who had previously been at the Met Office. According to him there's a simple reason for the discrepancies: "put two meteorologists in a room and they'll give you three mutually contradictive forecasts". ;)
  9. daft_biker
    Good point, half expecting them to say some other wear parts need doing too. Kwik fit will hopefully do it tomorrow for £100 a spring. Might have been a little less at the saab specialist but that's 10 miles of back roads away rather than a couple of streets so not worth the risk even if they had availability, which seems unlikely given how far ahead I usually have to book with them.
  10. GeoffR
    That I can believe!
  11. GeoffR
    What are the trailing arm bushes like?
  12. daft_biker
    From memory they look perished on the outside.
  13. GeoffR
    While the back end is in bits it might be worth getting them done too, though I wouldn't really want KwikFit anywhere near them if it were my car.
  14. daft_biker
    The local lads seem pretty good...I used to give them cheap steaks and hot food ;). They have a lot more tools and experience than me anyway and seem to enjoy good relationships with customers.
    £200 for a glorified oil change though...I'll go elsewhere for that!
  15. GeoffR
    Very much a case of "where they are good they are very good and where they are bad..." Anyway, the trailing arm bushes will cost you a pair of tyres if they fail as the tyres wear very quickly indeed!
    daft_biker likes this.
  16. Catriona
    Catriona Well-Known Member
  17. spinno
    I've struggled with these before- my acuity is worse from red up/down to blue and overall it's not good.
    Perhaps I'll stick to black and white
    Catriona likes this.
  18. Catriona
    Strange isn't it? Blues and reds, I was perfect it was just the greens that I slipped on differentiating the hues.
  19. RovingMike
    Hmm, I thought I did OK, but it scored me 30, just in top third. Didn't say where I went wrong and I couldn't tell.
  20. Catriona
    Didn't you get the chart above your score? Funnily enough my score was also 30. A few years ago I remember it was 4. The chart shows all the shade and a histogram of where you boobed.
