Well, it’s better than I thought..
Discussion in 'Lens Matters' started by pixelpuffin, Jul 3, 2021.
  1. pixelpuffin
    pixelpuffin Well-Known Member
    625FCA74-B731-48E0-A45D-474119E72971.jpeg I recently discovered the canon EF 22-55. It’s a long discontinued consumer lens, plastic mount ,ultrasonic motor. But, it fits full frame.
    I had to try one…
    £46
    Mounted it on my canon 5diii and popped outside into the garden. I love the colours. I’m quite chuffed tbh. Seems better than I was expecting.
    Gezza, Learning, zx9r and 2 others like this.
  2. Learning
    There seems to be a strong rule of diminishing returns between cost and complexity to image quality when it comes to lenses.
    Benchmark likes this.
  3. Chester AP
    There is often a lot of complete bollocks written about lenses. If you don't want very large prints from the images, it can be surprising how little you have to pay to get something that gives image quality that is good enough for your needs. The same, of course, applies to camera bodies and digital sensors.
    Whenever I read about lenses with four figure prices that are used for portraiture, I always suspect that they will show so many minor skin blemishes that the subject might prefer the results from a 'softer' lens.
    Be advised that the above are personal opinions, and should not be mistaken for factual statements.
  4. spinno
    If anyone's interested I have jamjars which have superb optical qualities
  5. Andrew Flannigan
    Bottom of a glass works as well...
    Zak52, zx9r and Terrywoodenpic like this.
  6. Benchista
    It was designed for APS - it was the kit lens for the EOS IX7, the cheaper EOS APS SLR - the IX came with the 24-85. It does cover full frame, though. Produces quite nice colours, but it's not all that sharp. Probably doesn't matter for many things.
    It's rumoured that it was this lens that was stretched to make the original 18-55 EF-S kit lens, but I've no idea if that's true or not.
  7. pixelpuffin
    personally I think it’s sharper than you’re giving credit for.
    The above image is reduced massively for uploading here, whereas the image I took viewed at full image size on my monitor is sharp indeed where I focused
    It was taken handheld, @55mm wide open at 5.6 add the slight breeze blowing too
    I think it’s remarkable, it’s now attached to my 5diii.
  8. Chester AP
    It is a common opinion that the world often looks better through the bottom of a (preferably empty) beer glass .
    If you want to experiment with abysmal image quality, and can write the required complete bollocks to accompany your images, look at page 23 in the AP issue dated 29th of May for inspiration.
  9. gray1720
    gray1720 Well-Known Member
    ...or that article on box cameras....
  10. Andrew Flannigan
    No need - just forget to set things correctly...
  11. SXH
    SXH Well-Known Member
    Or the LOMO site?
  12. Chester AP
    Don't admit you made a mistake, but give it a pretentious name ('Walking Home After the Rave'?) and submit it to next year's Taylor Wessing competition.
  13. Learning
    I could not do that if I tried. How did you do it?
  14. spinno
    Followed a google streetview car?
  15. Andrew Flannigan
    I really have no idea. I was using a Panasonic GM5 with an Olympus 9-18mm lens. This is the only shot like that which I have. :confused:
  16. Terrywoodenpic
    How very strange
  17. spinno
    Double exposure of some sort, things in motion show movement.
    You could start a whole new fad Andrew!
  18. Andrew Flannigan
    Aaaaarrrrrggggg! :eek:
  19. gray1720
    Accidentally changed the curtain sync on the flash?
  20. Andrew Flannigan
    No flash fitted. :(
