Transfering RAW images from Fujifilm S5 Pro to PC??
Discussion in 'Fujifilm Cameras' started by mr_london_lover, Mar 28, 2008.
  1. mr_london_lover
    mr_london_lover Active Member
    How do I see what version the ACR plug-in is ?
  2. LargeFormat
    LargeFormat Well-Known Member
    The lowest cost possibility might be to buy PaintShop Pro. It imports most RAW files although I haven't tried RAFs.
    By the way I don't see how restricting the download to someone with the program already in place prevents piracy. It's only going to be of any use to a Fuji user anyway.
  3. Fen
    Fen The Destroyer
    The OP doesn't have the program.
    Without the program you can't install any updates/new versions. Thereby stopping other people using it.
    I agree that it's only of use to Fuji people though :)
  4. Norman
    Norman Well-Known Member
    If you can't get hold of the Fuji software you could try RAW Therapee which is free (you can make a donation if you like it). This isn't an endorsement as I've not used it but hear it's OK.
  5. mr_london_lover
    Hallelujah!!!!!!!!!! Finally I find some software that actually works!!
    If there is anyone out there in the same boat as me this little piece of software does the job! Looks a good piece of software too. Thank you all for all your help!
    FastStone Image Viewer
    http://www.snapfiles.com/get/faststoneviewer.html
  6. sillyconguru
    sillyconguru Well-Known Member
    In CS go to "Help > About plug-in > Camera Raw".
  7. mr_london_lover
    Probably why it didn't work with the DNG files....I got version 2.0
  8. Norman
    CS will support ACR up to version 2.4. See if you can download that version from Adobe.
    Get it here.
  9. mr_london_lover
    Hey Norman
    I just downloaded that and it downloaded an updated RAW Plug in. My PhotoShop CS has upgraded from 2.0 to Version 2.4
    However it still doesn't recognise these RAF files even though its now version 2.4.
  10. Burgy
    Burgy In the Stop Bath
    according to adobe
    So you should be able to convert to DNG and then open in Photoshop CS.
  11. photogeek
    photogeek Well-Known Member
    Finepix viewer should have come with the camera, but if you are going to shoot a lot of RAW then I would recommend you buy the Hyper Utility tool HS-3. This will give you more control of your RAW files to process them before transfering into Photoshop for any final tweeking.
    Hope this helps
  12. Carrie
    Carrie Well-Known Member
    Looks like London Lover has managed to find something to open the files OK (looks like a useful piece of software)
    After that I'd be inclined to forget about the Fuji software, just convert to TIFF or DNG and do whatever processing you want in the software that you have.
  13. CplBadboyUK
    CplBadboyUK New Member
    Never had this problem... mac user here!! Thats the reason i stopped using PC's!
  14. GeoffR
    Whether you use a Mac or a PC you still won't open files without appropriate software. The problem was that the OP didn't have the Fuji software and wanted to know what else would do the job.
  15. Nig
    Nig Well-Known Member
    also this, s7raw
