One for you engineers and DIY bods. I am trying to remove the filter on my FIL’s washer/dryer. The cap unscrews but the filter doesn’t as I assume it is jammed. There are two lugs on the filter but there is no space to grip them from the outside so what I am looking for is something to grip inside the lugs. Something like inflating a balloon inside a jar. Difficult to describe and I don’t have a picture. It is all plastic If necessary I think I could use force to unscrew it but it would probably be damaged. Probably needs a new pump anyway.
You could try a pair of water pump pliers opened out to the internal diameter to engage with the lugs. It's how I unscrew the plastic screw caps on the 200l blue barrels at work.
I can’t visualise it. If a filter is meant to unscrew then you should be able to get at it but it probably needs the case off the machine.
Similar to the insertion of a stent from the description...the balloon goes through the coronary artery, is inflated to clear the blockage and the stent is left as the balloon is withdrawn. Anyway the matter in hand, rubber gloves may give purchase, or if you have a silicon object, (mat to put hot items on).
Ok I watched a couple of videos - agree with Martin that water pump pliers might do the trick. The filter should just pull out.
Not sure I'm visualising it right but would a pair of scissors work, by spreading your fingers in the opposite direction to closing the blades?
I suspect you are looking for circlip pliers https://www.screwfix.com/c/tools/pliers-cutters/cat831008?plierscuttersproducttype=circlip_pliers
This would probably work, but any other suggestions: https://www.amazon.co.uk/Strong-Too...704W1RYSEQH&psc=1&refRID=G0ZPQTC6W704W1RYSEQH
What make of machine is it? The videos I found for washing machine filters just showed a screwcap to which the filter was attached and just pulled out. I assume the filter is a bayonet fit to the cap. The filter itself in the videos was a loose fit in the holder. Did you try winding some cloth around your hand, then making a fist to grip the inside of the filter? Edit: just a thought. Is there a filter in there? It is supposed to be attached to the cap. Are you trying to remove the filter housing, someone previously having taken the filter out and not replaced it?
Thanks Pete. I think the filter is supposed to be attached to the cap but because it is jammed, the cap just turns and is easily removed, but the filter does not move. It is unlike any filter I have seen before. Perhaps Neff make them difficult so that a new pump is the only option. I don’t mind trying anything on my machines as I can only blame myself if it goes wrong. This attitude is more difficult on machines that are not mine particularly where the person is looking over my shoulder and panics at every move, even if he is well into his 90s.
Having watched a few more youtube videos - debris can jam the filter. They all show pump removal and extracting debris from inlet to filter via the pump assembly (filter holder inlet) - looks straightforward but involves (safely) tipping the machine to get in from underneath. I didn’t see a Neff video but they all seem to use the same basic approach. Edit - having turned it off, power and water supply.
Nothing worked so I had to use a screwdriver which damaged the filter. Completely filled with calcium deposits. New pump is my next step.
