The starry night.
Discussion in 'Appraisal Gallery' started by robbinsd, Sep 26, 2014.
  1. robbinsd
    robbinsd Member
    Well, yesterday, we saw a new moon in the UK. The sky was at its darkest, and at about 3am, the clouds cleared for just long enough for me to snap this photo of a tiny little church in Rural South Wales, UK.
    Let me know what you think!
  2. luisport
    luisport Well-Known Member
    I see no place within the shot for the left invasive branches. I think there has something to be done with the vertical lines so the crosses look like straightly be heading to the Via Lactea. If while erecting the crosses you could try a crop and play with the descending diagonal... IMPO, it'd be a great improvement. A smaller foreground should allow greater meaningful play with the church and stars. Scrolling the image upwards almost corrects the diagonal issue I mentioned before.
    I like the stars but the church and church yard look wrong, did you rotate the image because the verticals were converging? You have to be very careful on composition if using an ultra-wide lens and pointing it upwards.
  4. robbinsd
    robbinsd Member
    OK, thanks for the feedback. Im not 100% sure what you mean but I have tried to resolve the warp caused by the wide angle lens. The church was build of a rather steep incline, which doesn't help my case, it isn't build on flat land.
    How do you feel about this image? [​IMG]
  5. El_Sid
    Can you post the original as-shot version so we can see what any issues there are/may be with it?
    Personally aside from the branches on the left (clone tool time) I was quite happy with the first version. I assumed since it's South Wales that the chuch is on a hillside...;)
  6. robbinsd
    robbinsd Member
    Sure thing!
    I study in Birmingham, and it's such a novelty just being able to walk down a road without an incline!
    This is the RAW image, straight out of the camera. Just a note, I shoot with a Canon 6d, which has a built in level, so these were shot with the camera perfectly horizontal.
    The incline that you can see is due to the incline of the ground, not the camera being on the squiff. There really is very little distortion due to the lens.
    Dan
    I also have this photo, which i took from a different angle.
  7. frank1
    frank1 Well-Known Member
    Why can't some people accept the hills. I have to cycle up some of them and it's not easy but they're there and they won't go away.
    Nice image great to see the Milky Way I'm barely able to see the Plough these days living in London.
  8. El_Sid
    No not a lot of distortion there. Not quite sure what you did to the original post but there did seem to be a bit of added distortion that doesn't look quite real - the gravestone front left for instance has a distinct slope on the top edge.
    This is my rough attempt at perspective correction using Pixlr...
    Here the crosses are pretty much vertical and the gravestone is still rectangular. This was done simply by pulling the left side over using the distortion tool and then stretching slightly to get the height proportion about right.
