That, quite seriously, is one of the last things I want to have galloping around the place while I'm trying to get some kip! Cheers, Jeff
SXH......Yes it was taken at night, it had spun its web across the doorway of our camper, I took several shots of it before it moved, it was very dark I had no other option but to use flash, some of the nearby campers came around to my place to see what all the flashing was about, when they saw the spider they said it was only a baby, so I would have hated to have seen its parents, thanks for the info.......
No need to worry. According to Wikipedia, "Their bite is not dangerous to humans but may induce mild, local pain, redness, and occasionally swelling for a period of 30 minutes up to three to four hours."
And talent, of course. But I'm not used to the Nikon menus yet and haven't found the talent-boost option yet... .[/QUOTE] Don't bother, there isn't one, I've looked... They don't have it on Canons either - and you know how they love gimmicks...[/QUOTE] Er, moving from Nikon to Canon IS the talent boost.
I seem to remember that CCD were reckoned more sensitive and were less noisy than CMOS. Certainly my D50 seems to produce cleaner images than the roughly contemporary 20D, it also had a base ISO of 200 which suggest a greater sensitivity. Another feature which IIRC is linked to it's having a CCD is that it can flash sync up to 1/500sec by somehow using the CCD as an electronic shutter - presumably the firmware turns the CCD off then on for the set time and then off again before closing the shutter. The colour may well be down to changes in the JPEG processing parameters as I daresay these tend to be adjusted between as sensor improvements come in.
