Tamron SP 90mm f/2.8 Di Macro VC USD - Any Good?
Discussion in 'Lens Matters' started by Darth Vader, Jul 27, 2020.
Tags:
  1. Darth Vader
    Darth Vader Active Member
    Please can someone give me some advice on the Tamron SP 90mm f/2.8 Di Macro VC USD lens for a Canon 5D mk3, thank you.
    I am looking for a macro lens but only have up to £500.
    I’ve not used one but the Tamron and the slightly longer Sigma are supposed to be good. AP uses the sigma as a reference lens.
  3. MJB
    MJB Well-Known Member
    I have a friend who uses that lens (Sony fit) and he's impressed with it. As Pete suggested the Sigma 105mm F2.8 EX DG OS HSM is worth considering as it is also highly regarded. It is also cheaper than the Tamron if budget is a major point. The Sigma is also fully compatible with Canon's 1.4x extender.
  4. Stephen Rundle
  5. Stephen Rundle
    How about this
    https://www.wexphotovideo.com/tamron-90mm-f28-sp-di-macro-lens-canon-fit-1001403/
    Or check pre owned, new is more than £500
    https://www.digitalcameraworld.com/uk/buying-guides/best-macro-lenses
    Really if you have a Canon then why not Canon, I had one,they are good no vr
    https://www.wexphotovideo.com/canon-ef-100mm-f28-usm-macro-lens-12862/?s=1&mkwid=sMXE0VImz_dc&pcrid=324254351732&kword=canon 100mm macro&match=e&plid=&si=PPC&gclid=CjwKCAjw9vn4BRBaEiwAh0muDJhpenTvZWZvhzvgxzXXbhzLtlsSGzw382-thXl1YHzPUT0I84MBdxoCQtUQAvD_BwE
  6. Craig20264
    Craig20264 Well-Known Member
    Just sold mine (Nikon fit). Absolutely tack sharp lens, although I did have front focusing issues with it.
  7. Benchista
  8. Dorset_Mike
    Dorset_Mike Grumpy Old Fart
    Another vote for the Tamron, had mine for many years.
  9. beatnik69
    beatnik69 Well-Known Member
    I have the older version without vibration control and it is very good. It's sharp, but can hunt for focus a bit.
  10. Andrew Flannigan
    The Tamron's pedigree goes back to the AD2 manual mount version, which I still use. It's always been a good piece of kit...
  11. GeoffR
    Am I imagining things or is there a set of Nikon "rabbit ears" on that lens?
  12. SXH
    SXH Well-Known Member
    Nikon fit lens with a Canon adapter?
  13. GeoffR
    Possibly, I don't think the AD2 mount was ever adapted to the EOS range but I am probably wrong on that.
  14. ChrisNewman
    ChrisNewman Well-Known Member
    Both the Tamron, and the Sigma 105mm mentioned in other replies have excellent reputations.
    I have the Nikkor AF-S 105mm ƒ/2.8G IF ED VR. Personally I appreciate the 105mm focal length over shorter macros, as I’m particularly keen on photographing butterflies. But your needs will depend on what you want to use it for.
    One reason I chose the Nikkor over the Sigma was it’s smaller maximum aperture (f/32 compared to f/22), and I sometimes use minimum aperture on a tripod for fungi, etc, because depth of field is so limited with macro (unless you get into focus stacking). I think the Tamron also goes to f/32, and, along with its shorter focal length, it’s a little lighter to carry.
  15. Andrew Flannigan
    AD2 Nikon mount plus Nikon to Eos adapter. It worked well. I've now switched to a Nikon D600 and that works even better. :)
    There are third party AD2 to Eos adapters but the ones I tried were completely dumb and didn't inspire me with confidence.
  16. Chester AP
    I've got one of the 'first generation' autofocus Tamron 90 mm F 2.8 lenses (circa. 1997-8) that I purchased second hand for £230 in 2011 (when I recall that new ones were £370-£380). So no image stabilisation, but capable of very sharp images if used carefully. I use it on a half-frame (APS-C) DSLR and have found that it is also excellent for 'non macro' shots too when used as a short telephoto (135 mm equivalent on my camera body, but the 90 mm on your camera body would also be good for portraits).
    A new lens is about £630-£650 in the UK now, so your budget isn't big enough (some retailers still list the previous non-VC version for about £400 but out of stock). If you plan to use it mostly for macro work, will you be using a tripod? If so, you could consider looking for a secondhand older model without 'VC'. And if you don't have a tripod, the saving would provide the funds for one within your £500 budget.
  17. Bazarchie
    Bazarchie Well-Known Member
    I have a Tokina Canon Pro D AT-X M100/2.8 Macro. AF is slow but otherwise a fine lens. Much cheaper than the Tamron.
  18. ChrisNewman
    If I set out to take macro shots of something static, I take a tripod. But many of my macro shots are hand-held, because butterflies, etc, don’t wait for you to set up a tripod (except for real enthusiasts who look for them on cold dawns), or because I just see an attractive plant or fungus when out walking. If I forget to switch on image stabilization, my shots are rarely sharp. So if you’re likely to use your macro lens without a tripod, I’d strongly recommend getting a lens with image stabilization.
    MJB likes this.
  19. gray1720
    gray1720 Well-Known Member
    I've occasionally used the mother-out-law's manual focus one - lovely thing, pity about the idiot using it. Adaptall mount, which probably dates it!
  20. Andrew Flannigan
    Probably the same version illustrated at #9
