I just took delivery of a genuine Sony battery in a Sony blister pack for just £15.50 from an Ebay seller in Hong Kong. As I`ve mentioned before I bought a third party Duracell battery that the camera wouldn`t accept.I got the message"infolithium only" Here`s the one,pounds cheaper than uk sourced ones. http://www.ebay.co.uk/itm/261731985131?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I'd be amazed if they were genuine at that price . That seller is new with little feedback , but what negative has been left is for fake batteries . With this type of Sony battery a quick check can be made by looking into the end of the terminals . Genuine Sony ones are solid in the bottom of hollow area . Fakes have a small hole at the bottom of it . This is the same in all three terminals , and seems to be the only consistent feature of all fakes . I Look forward to an update . If it's not clear the bit I mean , let me know and I will take a shot of my genuine ones and a fake . Third party batteries also have these holes in them , but they don't claim to be something there not . Fakes and forgeries are big business , the batteries used can cause problems or even overheat when charged .
I don`t quite see what you mean Neil. My camera,A350,immediately rejected a Duracell third party battery with the phrase "infolithium only"which suggests to me that only genuine Infolithium Sony batteries will be accepted. The camera immediately accepted this new battery showing 75% charge.The Sony battery that I bought with the camera and the new one are identical in every way.All three terminals are hollow.I guess that`s what you mean? I also looked on the Sony website and their photo of the NP-FM500H shows the terminals to be hollow also.So what does that tell you?
The issue is that although the chip in the battery is recognised by the camera , the rest can cause problems . If your lucky the cells used die after just a few month's and won't hold or accept a charge . If your unlucky the bits that regulate the power could cause problems . Third party batteries , even cheap ones don't normally cause issues . Quality and how long they last is a different thing . I bought some cheap batteries when u got my a580 as they used a different battery than my a100 . They worked fine for about 6 months , by which time I had got some more genuine Sony ones . The fake ones tend to have more spent on the forged packaging than the battery inside . I'm at work today , but can post some pictures of the bit I mean later , if I can work out how to make a post on my computer . This new forum hasn't got a reply box in windows 10 for some reason . I'm typing this on my phone . If you look at the terminal of a genuine Sony battery , they look like a bucket , is , a hollow tube with a flat , solid bottom in it . In third party and fake batteries , when you look into the terminal , it's like looking into a bucket with a hole in the bottom . When I get home I will try to post a picture . A pictures worth a thousand words , but I can't figure out this new forum layout ! I will try though .
I've got a third party FM500H and the terminals are solid ie the bucket ain't got a hole dear Liza. Unfortunately it did work but won't any longer. The camera reports battery as not compatible.
