Sony 18-70mm Kit Lens broken?
Discussion in 'Sony Chat' started by DaveBee, Jan 12, 2010.
  1. DaveBee
    DaveBee Member
    Hello, newbie first-poster here.
    I've had my A200 for just over a year now and I'm enjoying it thoroughly. Yesterday though, my wife went to turn it on and it started making the most horrendous grinding/buzzing noise from the autofocus motor. This is with the 18-70mm kit lens attached.
    I took the lens off and tried both of my other lenses and the camera functions perfectly with those.
    When rotating the focus ring of the kit lens (off the camera) there is a definite notch or sticking point about midway round... not much, but evidently enough to throw the autofocus motor into hysterics.
    Has anyone else come across this problem? Is there an easy fix? I imagine sending the lens to Sony for a repair would cost more than replacing it, so does anyone know of a good independent lens fixer? I'm in South Devon.
    I have downloaded the service manual so I have the drawings for it, but I'm not really up to taking it apart, unless it's completely non-fixable. However, if I loosen the four screws that hold the attachment plate, then rotate the focus ring, the sticky spot is not there.
    Thanks for reading, and for any advice anyone may be able to offer.
    Cheers
    Dave
  2. Steve52
    Steve52 Well-Known Member
    Hi and welcome to the forum.
    My A350 developed a fault, and although it too was just over a year old and supposedly out of gaurantee, I managed to get it repaired free of charge.
    Might be worth taking the lens back to the shop where you bought it and asking. You have nothing to lose.
    Sorry can't help with the dismantling or a repair shop.
  3. DaveBee
    DaveBee Member
    Thanks for the reply Steve. I'll try the original supplier... fingers crossed.
  4. john39
    john39 Well-Known Member
    have you tried Photclub Alpha for advice or Camera Workshops in Milton keynes (cameraworkshop@tiscali.co.uk)? Or look on fleabay for replacement, to gauge cost and if repair worth it, then again sounds like a good excuse to upgrade - funds permitting of course
  5. DaveBee
    DaveBee Member
    John, thanks for the recommendations, I will try those too. I would like to upgrade to the Sony/Tamron 18-250mm lens, but I can't justify shelling out £300 for one.
    In the meantime I have two old Sigma lenses, 35-70mm and 70mm-210mm from my wife's old Minolta 35mm which work fine. I just miss the 18mm wide angle for landscapes.
  6. DaveG40
    DaveG40 Well-Known Member
    The sal18250 (18-250) is an excellent lens, but as you say it's pricey, here's a gem that goes un-noticed, but imho is almost as good as the 18-250, and it's half the price (if you can find one), Sigma 28-200
    At the time i was sad to see it go (replaced by the Sony), given what's occured recently (see my other posts), I'm kinda glad i got rid of it, still if you don't go above an A380 you should be alright, I paid £120 for mine, brand new from an ebay store, I also tried the 28-300, it lasted a month (could'nt stand it), by all accounts the Sigma 18-200 is supposed to be quite good as well.
    If you're shrewd & lucky it is possible to buy a new/near new kit lens (18-70) on ebay for crazy money (I paid £30 once) and it was mint/unused.
  7. Gordon_McGeachie
  8. DaveBee
    DaveBee Member
    Thanks to everyone for the useful replies.
    Unfortunately the original supplier won't replace the lens as it's out of warranty, which I suppose is fair enough.
    Camera Workshops have come back to me offering to look at it for free with a ballpark figure for a repair.
    I have also found someone in my town who can possibly fix it, so I will have a chat with him first.
    I have a few options now.
    BTW, Gordon, I'm a bit of a fan of the Vulcan too... I took this at Yeovilton last year:
    http://www.flickr.com/photos/24681889@N03/3714745080/
  9. DaveG40
    The Vulcan's tucked away nice and warm at the mo :)
  10. yvaine
    yvaine New Member
    Hi,
    My Sony lens kit has exactly the same problem as the one you describe. I was wondering if you fixed the problem and how much did it cost. Mine is out of the warranty as well and I plan to contact Sony to have it repaired as I can't afford a new one at the moment :(
    Thanks a lot!
    yvaine
  11. DaveBee
    DaveBee Member
    No, it seems that the money spent fixing it will be a significant proportion of the cost of a new 18-200, so I'm just going to do that.
    Let me know if you have any luck fixing yours though... good luck.
  12. yvaine
    yvaine New Member
    Hi,
    Thanks a lot for your reply. I'm sending the lens back to Sony tomorrow. Hopefully they won't ask too much to fix it. I will keep you updated.
    yvaine
  13. Ed-209
    Ed-209 New Member
    Hi, Just noticed your original post. I know it quite old. but I have had the same problems with the DT18-70mm lens. The problem is the focus gear barrel is weak and a couple of the nylon gears teeth tear off. Easy enough fix. but you need to buy a new barrel costs about £10 inc the p&p. the strip down is a bit tricky. You will find it easier as you have the strip down instruction. I really need to get a set myself. I have fixed dozens of these lens funny enough all from sony alpha 200,300,350 must have been a bundled kit.
    Any problems contact me, I will help if I can.
    Cheers
    Ed.
  14. Christina.13
    Christina.13 New Member
    Hi Ed I live in New South Wales Australia - my lens has the same problem - I was about to throw it in the bin until I read your post. CAn you give me any long distance advise on hoe to fix? Where can I get the parts you are talking about close to home? Any help appreciated.:eek:
  15. Christina.13
    Hi Ed
    Apologies for the typos. One more thought - I would even consider sending it to you in the UK if you could indicate a price to fix the lens. Many thanks Christina
  16. nucnad
    nucnad New Member
    Dear Ed,
    I have a DT 18-70mm lens with the problem as you describe above. My particular example is an outstanding performer and I would far rather it be repaired than replace it. Would you be prepared to undertake this for me, and if so at what cost?
    Regards, Iain (nucnad)
  17. Steve52
    Hi Ed
    Posted a comment earlier. However, I have an old Sigma 70-30mm lens that's had it's gears ripped. Any idea where I can get the manual for it and the replacement focussing ring (I think that's what has gone) or barrel?
    As the thing is caput anyway and gathering dust on a shelf, wont matter if I make a pig's ear of trying to fix it.
    Thanks.
  18. Dorset_Mike
    Dorset_Mike Grumpy Old Fart
