Sigma Service Center Experiences?
Discussion in 'Lens Matters' started by Legojon, Jan 8, 2020.
  1. Bazarchie
    Bazarchie Well-Known Member
    I have a dock which I use for firmware updates. I agree lenses should work fine out of the box, but it seems this is not always the case. I tried to micro some of my Canon lenses last year but it was a tedious process and I am not sure I was correct.
    Returning to Sigma should give you more comfort than doing it yourself.
    Buying a dock for future use is still a good idea.
    To judge focus and depth of field you need to measure. Usually a plane target is set up at the required distance with a ruler running at a slight upward angle normal to the target and camera. Focus on the target and the ruler graduations that are sharp delineate the depth of field.
    The swan picture doesn’t look very sharp to me but I’m only looking on an iPad.
  3. GeoffR
    The D500 allows you to make adjustments to the focusing system, if you look in the menu you should see something like AF Fine tune (as it is called in the D4) . This may achieve what you want very quickly, I would read the manual first though.
  4. nimbus
    What you must bear in mind about depth of field is that it is not exact, the word "acceptable" is used in the definition, in other words it will not be quite as crisp elsewhere as the point on which you have focused. Other factors come into play, even at the aperture you are quoted for, such as diffraction starting to appear after around probably f8, reducing the resolution, which on modern lenses is highest at surprisingly wide apertures. That is before even considering an assembly issue, such as decentering.
  5. Legojon
    Legojon Active Member
    Just got a notification from Sigma my camera and lens are on the way back (tomorrow). So been gone exactly 2 weeks. Will see if it makes any difference.
  6. Legojon
    So... to conclude. I've got my camera back from Sigma. It was all packaged / bagged nicely. Obviously camera sharpness has many determining factors. But having taken 233 photos over the weekend (a lot of them of birds flying) there are only a handful that are soft. So from what I can tell, they've done a decent job of calibrating it.
