Hello, Long shot, I shoot with a hand strap which screws into the base of the camera, I am wondering if there is an extension or something so I can screw the plate for the tripod without having to unscrew the hand strap. Thanks
There are (or were) bars that screw into the tripod socket and provide 2 sockets. I'm not sure I'd want to trust a camera to a strap attached to one of those bars though. There's just far too much chance of something coming loose. In any case the lugs are where you should be attaching straps. If you need to swap straps quickly I can recommend the Op/Tech system which I use for my larger cameras: https://optechusa.com/
Blackrapid do some (over-priced) tripod plates that come with their screw in attachment point. How does your wrist strap attach to the screw?
Surely it only takes a few seconds to swap the strap for a plate? Plates are best kept on the tripod QR to avoid them getting lost. Though, thus said, I've managed to lose my monopod somewhere with a plate on a camera so I'm one plate up at the moment. I tend to render my camera "strapless" when using a tripod or monopod because the strap gets in the way. I use a conventional strap on the lugs and once you've done and undone it a few times it isn't the horrid fight experienced putting a new strap on a new camera.
If your tripod QR is an Aria compatible there are a few designs of plate that have a strap loop built in. So you can leave the plate on all the time. Failing that you could use a section of webbing with a D ring & a hole for the bolt to go between the camera & QR plate to give a anchor point for the strap. Again leaving the QR plate on all the time. Any QR plate that's not left on constantly is actually a slow release & should be avoided!
