Scanning problems
Discussion in 'Digital Image Editing & Printing' started by cliveva, Oct 12, 2020.
  1. cliveva
    cliveva Well-Known Member
    Using a Epsom v370photo, all resolution scans of a faded 8x4 photo result with banding in bright areas, is there any thing that can be done or do I need a better scanner. If so, suggestions please
    I had a problem like this I think I powered everything down and started again.
  3. cliveva
    Tried that, same effect
  4. Chester AP
    I've looked up this model and seen that it's a flatbed model - have you cleaned the glass plate with something that will remove any dust or grease deposits?
    I have a 14 year old flatbed scanner, and had this problem once when trying to scan an photograph with a very 'glossy' surface. Experience shows that matt finish photographs are less likely to cause problems.
  5. Bazarchie
    Bazarchie Well-Known Member
