Scanner vs Camera/macro lens
Discussion in 'Everything Film' started by Zou, Jul 3, 2021.
  1. peterba
    peterba Well-Known Member
    Have you experimented with the sharpening settings in darktable? As I recall, the default settings weren't so great. I'm no expert (and it was a while ago), but IIRC, I tried radius: 1, amount: 2, threshold: 1.
    If that doesn't improve things, I guess you might just try jacking around a little with the sliders........ you never know, you might hit upon settings that you like.
    The files size probably has little effect as they are probably expanded to the same pixel count x3 x bit depth internally, however they are stored. Factor two difference if one route is 8 bit and the other 16.
  3. Zou
    Seems snappier refreshing changes from the smaller file though?
  4. Zou
    Currently playing around with darktable to convert raw files to tif, then stitching with hugin. If this works well, I think 5x4 'scanning' will have suddenly become a lot easier. As it stands I scan in two strips and stitch but there isn't a proper film holder for this on my scanner, which wasn't designed for LF. So neg straight onto light box will likely end up flatter/sharper.
