Recommendations for Delta 400?
Discussion in 'Everything Film' started by Wilko, Nov 18, 2002.
  1. Larry Shone
    Larry Shone Well-Known Member
    no worries
    BTW, did you get my film?
    [​IMG] IRIPN
  2. RonM
    RonM Alpha Napper
    pushed two stops the recommended time for ID-11 (stock solution) is 14 and a half minutes.
    For information on B&W film development times Larry check out www.digaltruth.com and go to the 'Massive Development Chart' where you'll get times for almost every film/developer combination.
    <font color=blue>RonM IRIPN</font color=blue>
    Everyone has a photographic memory. Some just don't have film.
  3. Simon E.
    Simon E. Well-Known Member
    I'd suggest using Microphen or DD-X for these kind of speeds. These will give better shadow detail than ID-11 when used for push-processing.
    Simon.
  4. Larry Shone
    but we only have ID11 at college
    [​IMG] IRIPN
  5. Wilko
    Wilko Well-Known Member
    Did you get my film?
    Yes thanks Larry - it's already in my F90x. And you?
    Wilko
    Wilko
  6. Larry Shone
    Re: Did you get my film?
    Yes, it will be in my camera as soon as ive finished the roll i have in there.I'd like to push it to 1600 to get some grainy atmospheric shots but we only have ID11 at college.
    [​IMG] IRIPN
  7. Wilko
    Hi Larry,
    I've pushed it to 1600 developing in TMax - contrast was good and grain was OK too, ID11 is surely worth a try - it might be less grainy than you think. You can push it right up to 3200.
    ID11 undiluted @ 20deg C 14.5 minutes for 1600ASA
    ID11 undiluted @ 20deg C 19 minutes for 3200ASA!
    I think it needs a bit longer in the fixer than HP5, I'd give it at least 5 minutes - it always works for me.
    Wilko
  8. Larry Shone
    thanks for that Wilko, 3200 sounds good!
    I'll give it a shot!
    And i always fix HP% for 5 minutes anyway(we fix any film for 5 minutes at college, my last roll, well only roll so far, was Jessops Pan 100S, not a bad film!)
    [​IMG] IRIPN
