Quick filter question
Discussion in 'Lens Matters' started by ajbendel, Dec 4, 2017.
  1. ajbendel
    ajbendel New Member
    Hi, I've only ever used digital equipment till now. I've been given a film camera and some filters including a B+W 49ES CTO 12B. Obviously this is a 49mm size, but can anyone tell me what the filter does and what sort of film it should be used with? Many thanks.
  2. Andrew Flannigan
    There were queries back in 2005 on the forum about B+W filters not being listed in the hand-book.
  4. GeoffR
    I think the 12B is important and I am fairly sure it is a contrast control filter for use with black and white film but I cannot recall what a 12B filter is or does in any detail. Can you tell us what colour it is?
  5. RogerMac
    Afraid that I can not help you with the 12B but these pages from a 1957 manual might help
      File size:
      320.6 KB
      1
  6. ajbendel
    ajbendel New Member
    It's orange.
  7. RogerMac
    There you go:) Just remains for you to start some interesting experiments as to whether that table still works. If you are using an external meter don't forget the necessary exposure compensation suggested in the final column but ignore that if using an internal (post filtration) meter
  8. Andrew Flannigan
    Which knocks the KB12 theory on the head - that's pale blue. If it's definitely orange and not a sort of reddish brown then it's a straight forward filter for monochrome film as per Roger's table.
  9. Benchista
    CTO stands for Colour Temperature Orange, and 12B means it's a warming filter for colour (slide) film, although you could use it as a contrast filter for B&W.
  10. ajbendel
    ajbendel New Member
    Brilliant, thanks so much everyone. I bought some Tri-X recently, so hopefully the filter will work well with that.
  11. RogerMac
    Please post some of the results
  12. steveandthedogs
    And let us know what the camera is!
    S
  13. GeoffR
    Thanks Nick, I couldn't remember what the 12B was, should have looked at my old reference books instead of Google.
  14. Learning
    Great. It was most likely intended for B&W, but there's now't to stop you experimenting with colour!
    For B&W it will darken blue skies rather more severely than green or yellow; it will darken grass and other greenery.
    Now in the old days experiments with filters and film would take days and much expense. These days just regress to your digital camera, select B&W, and experiment to find out what the fiter does.
    Almost forgot, you asked for what sort of film it was intended for. Answer B&W Panchromatic.
  15. Learning
    Nick's answer is more accurate than mine. Sorry It was for colour. I was wrong. But it still works as I decribed for B/W pancromatic.
  16. Chester AP
