Panasonic FZ1000...
Discussion in 'Panasonic Chat' started by S1MON, Jun 3, 2021.
  1. S1MON
    S1MON Well-Known Member
    I'm thinking of buying a Panasonic FZ1000, the release date was June 2014, has there been much change in sensor technology since then? Would I be better off buying something more recent?
    I used to have an FZ20 which was brilliant for the time, I loved the simplicity and found as a casual photographer I took more creative photos with that than I've ever managed with DSLRs.
    The main technology change has been that the on-sensor AF has caught up/exceeded that of DSLRs. How much this has trickled down to Bridge cameras I don’t know. We have a Sony RX-10 iii, which is in the same sort of market as the Fz1000/2000. The RX-10 iv is reported to have vastly improved AF. If it matters to you (doesn’t much matter if you are interested in photographing things that stand still) you had better investigate and try one out.
  3. Andrew Flannigan
    I took a long, hard look at the FZ1000 and then got a second hand Sony A65 body with a Tamron 16-300mm. Bigger sensor, nicer finder and screen, more pixels. A little bit bigger and heavier but it suits me. Some pictures...
  4. cliveva
    cliveva Well-Known Member
    I had it’s predecessor, very light and versatile but let down by the small sensor. the LX100 is wider with a larger sensor and smaller size. The mk 11 is even better, with higher resolution.
  5. PeteRob
    I thought the FZ 1000 had a 1” sensor. That would be another tech change, using larger sensors in bridge cameras.
  6. cliveva
    The LX100 has a 3\4 sensor, so is bigger. I found it unfeaseable to crop and ended up FF with a D800.
  7. dangie
    dangie Senior Knobhead
    I have the FZ1000 and have always been extremely pleased with its results. I also have cameras ranging from compacts to full frame.
    Of course a full frame or cropped sensor camera in theory is capable of technically better images, but do you always need those technically better images? What are you going to do with those images? I’ve entered 16x12 images into competitions taken with the FZ1000 with no loss of quality either in sharpness, clarity or noise.
    Also would you be more likely to have a bridge camera with its 24-400mm lens with you, or a heavier more cumbersome dSLR with 2-3 lenses? Maybe you could go onto the internet and Google the size & weight of the FZ1000 then compare with the size & weight of a camera body plus the additional lenses you’d want. Cost of course is important. I would imagine you can get the FZ1000 for a good price. How much for a SLR body plus 2-3 lenses?
    Whenever I go walking, it’s the FZ1000 I usually take with me.
  8. Andrew Flannigan
    ...or, in my case, a not so much heavier, not much more cumbersome, APS 24MP camera with the equivalent of a 24~450mm lens and the option of a 15~30mm (equivalent) ultrawide?
  9. dangie
    But still heavier and still more cumbersome. If that’s not an issue to you then that’s ok.
  10. Andrew Flannigan
    Indeed. When size and weight are important, one of these gives me 24-400mm equivalent in my pocket...
