Panasonic 45-200mm in real world use?
Discussion in 'Panasonic Chat' started by Staropramen, May 2, 2011.
  1. Staropramen
    Staropramen Well-Known Member
    Does anyone have observations on the performance of the Panasonic Vario 45-200mm please?
    Web-wisdom suggests it's not quite as sharp as the 14-45mm Panasonic (not surprising), but that overall it seems a well behaved if unexceptional lens. I have tried several manual focus primes and zooms, but they are a real fiddle to use 'on the hoof', apart from the obvious lack of OIS and AF . . . .
  2. Zou
    I have very limited experience of this lens on my mum's GF1. The above comment sums it up quite well I think. If the OIS and extra reach isn't essential, I have heard that the Oly m.Zuiko 40-150 is optically marginally better, and much smaller too of course.
  3. spangler
    spangler Well-Known Member
    More than happy with the 45-200 on my GF1, good value for money IMHO!
    Toodle pip! Andrew
  4. Staropramen
    Sadly there is (still) a pretty poor choice of true M43 lenses, so it's more-or-less 'take it or leave it' with regard to the 45-200mm. OIS is a real benefit for my work, but I rarely need a lens that long.
    For me the ideal range would be the old 3:1 ratio, 70-210mm (F) class of lens, which was very popular and quite practical. So I am less than impressed with the M43 zooms and the general lack of overlapping ranges. 14-52mm and 35-105mm seem more logical to me.
    OK - I'll give it a whirl. Thanks.
  5. Zou
    I'm seriously considering a G2/G3 at the moment (if the rumors are correct and the G3 is to be announced imminently).
    With my Nikkors and Pentax lenses I would have 28mm to 400mm covered, but from 84-400 only with manual focus, hence I have also been umming and ahhing about whether I should just go for the 45-200 or not with the kit. Part of me says to hold out for the 100-300 which would likely get less use but be of more use, if you know what I mean - not so much an everyday lens but a great option for wildlife and abstract landscapes. Getting back to the point... If Panasonic could plug the gap with a 35-100 f2.8 or even f3.5 the Lumix system would be a much better proposition.
  6. Staropramen
    Zou, Cameraworld have a few 45-200mm left at £219.99 (Chelmsford only) - that's a very attractive price.
  7. JohnATR
    JohnATR Member
    I have the lens as it came with my camera along with the standard 14-42, I have tried it and it seems good but I would really need to try it in a situation that required it as within the city the 14-42 is sufficient. But its nice having it there in the camera bag for when it might be used. Got the twin lens kit for only £75 more than the standard kit so I think it was worth it :D
    some pics on my flickr page are done with the 45-200 when I was trying it out, but rarely at 200mm. Need to go to some air-shows, bird watching or covert spying to try it on full length :p
    http://www.flickr.com/photos/johnstoddard/
  8. Staropramen
    First impressions.
    Well made, and complete with decent hood and case. Quite heavy, but handles well on the G1. AF is quite fast and nothing to complain about.
    Vignetting - illumination fall-off - is very pronounced at focal lengths over c100mm and the wider apertures (f5.6 to f8) and which is still evident in blue sky shots at f11 @ 200mm. Vignetting is less noticeable in the shorter range at f5.6 onwards, but a trace remains.
    Sharpness appears fine for most (of my) purposes, and is good across the frame: shallow depth of field hides much corner softness. As with almost all Lumix images (going back to earlier models) a small amount of sharpening during processing is usually required, though with this lens this still leaves a little softness of fine detail in the image. Contrast is consistently good throughout the focal range.
    I haven't looked at distortions yet.
    Overall it seems a thoroughly decent lens which appears to have no significant bad habits, and 'out of the camera' images are good, though they do need little extra work to deliver best results.
