Painting camera bodies
Discussion in 'General Equipment Chat & Advice' started by IvorETower, Feb 8, 2020.
  1. IvorETower
    IvorETower Little Buttercup
    I've bought a few second-hand camera bodies over the years; generally they exhibit some damage to the paint (black or otherwise) exposing the "bare" plastic underneath. I've tried using various touch-up paints but it seems that nothing sticks properly to the plastic; the paint may initially go on, but it's not really "keyed" and slight knocks or rubbing soon has it peeling off.
    Any suggestions - primers to use first or type of paint to get etc?
  2. Learning
    I find that the major attraction of using old but still working kit is the battle worn appearance. Should you have a classic gem that might be of interest to collectors just never ever try to tart it up.
  3. SXH
    SXH Well-Known Member
    Would the special primer they use for fibreglass-bodied cars work?
  4. Catriona
    Catriona Well-Known Member
    I wonder about enamel paint. That could adhere?
  5. Chester AP
    Just tell people 'it's had a hard life' and live with its cosmetic appearance.
  6. cliveva
    cliveva Well-Known Member
    First clean surface with acetone or alcohol then try Hammerite primer then smooth black. If the surface to be painted is shiny rub down with a fine grade wet and dry emery paper.
  7. nimbus
    Generally painting makes equipment look worse imho. I remember somebody painting a Pentax 6x7 quite well and it still looked worse than it had done previously.
    Learning likes this.
  8. SXH
    Well, you could always go for the Pentax Q approach, that would take people's minds of any slight imperfections...
    :D
    Andrew Flannigan likes this.
  9. neilt3
    neilt3 Well-Known Member
    I remember not that longer Leica did some special edition cameras .
    Instead of coming perfectly painted they had rubbed them down in certain spots to make the "pre-brassed" .
    People paid an extra thousand or do for this !
    Be happy that yours are naturally brassed and not faked .
    The issue I see with painting is that after adding an etch primer and topcoat the thickness off paint will be greater than the original layer and will show up as a bump .
    To redo it proper you would need to dismantle the camera , sand down the whole section and respray it completely to do a proper / convinceing job .
    I've got a hundred or more cameras and most of the older ones show brassing , I have no issue with this and would never try to cover it up .
  10. IvorETower
    Ah, but there is a difference in "brassed" on good old metal camera bodies and the modern plastic ones, which in general terms show black plastic once the paint has become damaged.
    Anyway I have found a small pot of "Rust-oleum" general purpose touch-up paint in a local hobby shop. So far so good, but I think I may need to apply some clear varnish over it at the end.
    I purchase a rather marked ex-demo body at what I think was a bargain price a couple of weeks ago, and applying some chrome silver paint over the damaged exposed black plastic has made a dramatic improvement. I will aim to post some photos in due course (if anyone is interested...)
  11. neilt3
    I missed the bit about the camera being plastic bodied .
    Yeah , that just looks bad rather than adding patina .
  12. GeoffR
    Brassing can look OK but alloy bodied cameras show a dull grey where the paint has rubbed off, unless the area is regularly rubbed when the metal may show a shiny silvery finish. The latter is much more attractive than the former, and the paint on a Nikon is quite thick so repainting is practical, but finding the right primer isn't easy.
  13. IvorETower
    Let's try this...
    Above as advertised by what I consider to be a "leading Wiltshire camera shop"
    Application of silver enamel, now protected by a layer or two of clear varnish:
  14. neilt3
    That looks like a very satisfactory finish .
    If it proves to be at least as durable as the original coating , it would be a job well done .
    Either way , a small tub of that paint would allow the you to repaint it several times .
  15. Learning
    I noticed in this week's camera review that the rather elegant Leica M10 Monochrom has brass top and base plates. It should age beautifully with frequent use. If I were to buy one and use it often then by the time that I pop my clogs it will be worth more for my family than the mere £7250 that I would pay for it.
