Max transparency size for Epson v600?
Discussion in 'Digital Image Editing & Printing' started by gray1720, Sep 27, 2019.
  1. gray1720
    gray1720 Well-Known Member
    Trying to find someone locally who can scan half-plate glass negs, someone has offered the use of a v600, anyone know what the limit of transparency size it can take is? The info online helpfully says "Can take almost any film format", given that my v750 (I think) won't go beyond 120, that doesn't fill me with confidence!
    Thanks,
    Adrian
  2. Andrew Flannigan
  3. gray1720
    It's definitely not one of those! A bit of Gurgling suggests its actually a v500.
    Adrian
  4. steveandthedogs
    Light box and camera?
    S
  5. gray1720
    Done it before, if I can't find one...
    Adrian
  6. John King
    John King Well-Known Member
    120 Negative in the 6 x 9cm format is the max
  7. gray1720
    Bother, thank you!
    Given the amount of time I have available (it appears to be vanishing up a wormhole in the space-time continuum), I may end up seeing if the copy place up the road can do them...
    Adrian
