Kodak Colorsnap 35 - setting infinity focus.
Discussion in 'Classic Models & Marques' started by John Farrell, Oct 17, 2021.
  1. John Farrell
    This camera has no "B" shutter speed - in fact the shutter has only one speed. I removed the lens assembly to clean out the sticky old grease - the lens has to have infinity focus reset after this. Normally, I fix a screen to the film rails, open the shutter on B, and focus the lens. This camera needed a different approach. I used a tip I found on a facebook group, and placed a plastic ring between the shutter blades. This can easily be removed after focus is set.
    Zou, gray1720, Terrywoodenpic and 3 others like this.
  2. gray1720
    gray1720 Well-Known Member
    Between you and Chris Sherlock, I reckon NZ could fix most things!
    John Farrell and swanseadave like this.
