Iphone cameras ......
Discussion in 'Smartphone photography' started by MickLL, Sep 6, 2012.
  1. MickLL
    MickLL In the Stop Bath
    ...... do not work well at the circus.
    MickLL
  2. MartyG
    MartyG Well-Known Member
    Ice cubes ......
    ...... do not work well in active volcanoes.
  3. GeoffR
    Crampons......
    ......are not popular at ice skating rinks.
  4. Brian
    Brian Venerable Elder
    Facebook
    .........gets more and more appealing.
  5. spinno
    It's magnificent
    ....but it's not war
  6. MickLL
    OK Let me explain.
    I went to the circus with my grandson. I forgot my camera and had only an Iphone with me. The Iphone inbuilt camera was constantly fooled by the 'show' lighting, flashed when I didn't want it to flash and focussed on the wrong things.
    It didn't perform well.
    I can see that being cryptic doesn't work either.
    MickLL
  7. Brian
    If by cryptic you mean in the sense of being obscure I reckon you succeeded, sure had most of us fooled.
  8. MickLL
    You mind is too complicated. I was not obscure. I said what I wanted to say in just a few words.
    "Iphone cameras do not work well at the circus". What's obscure about that?;)
    MickLL
  9. Brian
    Nothing but the maxim " Never state the obvious" comes to mind.;)
  10. MartyG
    Oh, and there was me thinking we had just invented a new style of Haiku :D
  11. beejaybee
    beejaybee Marvin
    A misprint, shirley ... "more and more appalling" is a far better description of farcebook
  12. PhilW
    PhilW Well-Known Member
    In my experience as long as the light levels are not very low (high ISO = amazingly grainy) the iPhone has a reasonably capable camera even in tricky lighting situations.
    Like almost every other camera the thing is to take it off auto.
    So turn the flash off (option top left of screen)
    But even more importantly take control of the exposure. Without exposure control then you are knackered.
    If you tap the screen the phone will
    a) Focus on that spot
    b) It will meter off that spot
    b) is the crucial one as dof is so great with it unless you are shooting macro everything will be acceptably sharp.
    I havn't tried to work out if it is spot metering or centering the metering area on the "tap" but just by tapping around various areas you want to be mid tones does give a good deal of control.
    Hope that helps for next time
  13. MickLL
    Thanks Phil. That's really helpful.
    I've only had the phone for a short time and although I like it the lack of instructions are a bit of a handicap for an old codger like me.
    MickLL
  14. Dorset_Mike
    Dorset_Mike Grumpy Old Fart
    I nominate the above for best post of the year!!!!!!!!!!
  15. PhilW
    Yes Mick, but "you don't need a manual" is an apple mantra :p
    I think i discovered the above by accident, i think i knew about selecting the focus point from somewhere, and just observed the exposure changing with it.
    It really is a capable little thing though.
    See below for a set I took over three days at a music festival in some quite varued lighting situations. Note the lack of many low light shots though. \those are the iPhones real weakness.
    http://www.philwinterbourne.co.uk/cropredyinsta/index.html
  16. GeoffR
    The instructions for the iPhone are available as a free download from iTunes in the form of an eBook. Search for iPhone User Guide.
  17. TheFatControlleR
    TheFatControlleR :Devil's Advocaat: Forum Admin
  18. Chris Cool
    Chris Cool Retired
    I did not think your post was obscure Mick - but I could understand a FB person thinking so lol ;)
  19. PhilW
    So it is, thanks :)
    The pertinent bit is:
    "A rectangle on the screen shows the area where Camera is focusing the shot.
    Change the focus area and set exposure: Tap where you want to focus. Camera
    automatically adjusts the exposure for the selected area of the image"
    It doesn't explain the metering mode used, but as you can see what's happening on screen you probably don't need to know that (however interesting it might be to photo geeks such as me!)
  20. LesleySM
    LesleySM Well-Known Member
    I have an HTC One S and recently it wasn't assessing the internet so I went to the website, which has a wonderfully simple help screen, you select your problem answer a number of Yes/No questions until you reach a solution.....Mine was switching the airplane mode on then off again, which worked but left me puzzled as to how I could have worked it out in the first place or indeed even why it worked at all
    Interestingly a friend had the same problem with her Samsung Galaxy and switching the airplane mode on and off solved it
