Ilford Delta 3200 developer
Discussion in 'Everything Film' started by Simon, Feb 4, 2003.
  1. Simon
    Simon Well-Known Member
    Whats the best developer for Ilford Delta 3200? I'm using Ilfosol S at the moment (as that's what the guy in the shop reccomended for my first attempts!) but I don't know if this will work with such a high speed film. I've only used it with HP5 so far.
    Is there anything I need to watch out for when I'm developing this film? Are higher speed films less tolerant to temperature/timing variations? The mere fact it has the word 'Professional' in it's name is, for some reason, making me nervous!
    Simon
  2. Benchista
    I use Kodak TMax developer with it, and am perfectly happy with this combination.
    Bear in mind that Delta 3200 is really slower than 3200, and so needs push processing (times published take this into account) - I wouldn't go under the quoted time or temperature.
    Nick BSRIPN
  3. dungbeetle
    dungbeetle Well-Known Member
    I also use it with TMax and get good results. You need to be careful when loading your tank that you have no even tiny light leaks in your room. On most photographic products, the word 'Professional' means just about jack shit.
    Wilko (alter ego mode)
  4. Simon E.
    Simon E. Well-Known Member
    I use Ilford DD-X or Microphen, as I usually want to extract as much shadow detail as I can from this film. Tolerance to time/temp is average as far as I can tell, I usually give it about 9mins in DD-X 1 4 after exposing at 800asa. Microphen is cheaper than DD-X but is a powder, and a pain in the arse to mix up.
    Ilfosol-S will surely work fine with this film, but it probably won't give you the best negatives if you want to expose it at 1600asa or above.
    Ignore the 'Professional' label, it's just marketing guff, a load of old b*ll*cks.
    Simon.
  5. Benchista
    On the "Professional" thing, in this case it means nothing, but film is about the only place where it does mean anything in photography - professional colour slide films may not differ in terms of the emulsion from their amateur breteren (Astia is the same as Sensia, for example), but they are aged prior to release and thus need to be stored cold to keep them fresh.
    Nick BSRIPN
  6. tamos
    tamos Member
    I use microphen as per the instructions for delta 3200 and pushing HP5. I've been happy enough with the results. The only other developer I've used (with any film) is ID11. I'm planning to try some other developers once I've moved house and can unpack some stuff.
  7. BigWill
    so "professional" = "but they are aged prior to release and thus need to be stored cold to keep them fresh."...........explains why Burgy goes off in the sun then! /img/wwwthreads/smile.gif
    BigWill
    <font color=blue>I'm sailing like a driftwood on a windy bay!<font color=black>
  8. Simon E.
    Nick,
    this doesn't explain the use of "professional" on boxes of Ilford Delta or Kodak Tmax black and white film, none of which is 'aged' or refrigerated before sale. It is merely marketing. Storage conditions for these materials are the same as for other emulsions.
    Simon.
  9. Benchista
    Exactly - that's why I said it didn't apply in this case.
    Nick BSRIPN
  10. Simon E.
    Brain fade
    That's my excuse, anyway. Sorry Nick, I should have read it properly.
    Simon.
  11. Benchista
    Re: Brain fade
    I'm having one of those days myself, Simon!/img/wwwthreads/smile.gif
    Nick BSRIPN
  12. BigWill
    Re: Brain fade
    ........bit like how camera makers describe some cameras as being "pro" models. Some genuinely are but with others I reckon it is just marketing hype.
    BigWill
  13. Benchista
    Re: Brain fade
    Some you have to be a pro to afford, the rest it's indeed hype!
    Nick BSRIPN
