ID11 .. is it me ?
Discussion in 'Everything Film' started by Stephen Rundle, May 27, 2020.
  1. Stephen Rundle
    See both images, the first one is from Ilfords data sheet download the second from ID11 card insert ????
    FP4 development times at 125asa ?????
    Is it 14 or 21 minutes at 1-3
  2. Andrew Flannigan
    Unless it's a simple misprint it could be all about contrast, which is a big subject with monochrome film.
    The simple rule of thumb is that if you print a 35mm frame in an enlarger using point source lighting and condensers you want to develop to a lower contrast than when you print roll or sheet film in an enlarger using cold cathode (diffuse) lighting. The longer the development the greater the contrast (all else being equal) because the shadow areas have fewer activated halide crystals while the lightest areas have more.
    This is an old, old negative of mine which is overexposed and over developed. Can you see how the shadows have blocked up?
  3. Stephen Rundle
    ID11 is a film developer not a print developer I am asking about film processing times which can be critical not print processing
    Awaiting return from Harmans
  4. Andrew Flannigan
    So was I. :rolleyes:
    Stephen Rundle and neilt3 like this.
  5. Stephen Rundle
    Right, another ID11 question................... anyone
    There is a LOT of confusion on the web (I'll be taking up with Harmans when they return (Ilford UK))
    When made up to 1Ltr do you use it as is or dilute ????
  6. spinno
    Either
    You can use it as stock solution or dilute it for economy
  7. PeteRob
  8. John Tarrant
    John Tarrant Active Member
    Historically FP4+ developed in ID11/D76 diluted 1:1 works well at 100 0r 125asa. FP4+ and its predecessors are well known for their excellent exposure latitude. Incidentally I find that using a dilution of 1:1 is an excellent way of providing development consistency rather than economy.
  9. Stephen Rundle
    ALL THREE of thesE are from Ilford, the developer box, the factsheet and the download (Harmans) so which one would you follow ???
    a1.jpg a2.jpg ?
  10. spinno
    Clear as mud but as with all these you have to be capable of reading in two directions at the same time
  11. Stephen Rundle
    When you over develop a film say 15 minutes instead of 8 what would you expect to see, once I would have known the answer :(
  12. Stephen Rundle
    Thanks then you answer this, BOTH of these pages are from THAT sheet ???????????? !!!!!!!!!!!!!!!!!!
  13. spinno
    What they've done is pivoted the values round, they are the same, but because they've "changed direction" they appear to be the wrong values if you don't look closely at the exposure values and dilution values and developing values.
    Top Table stock solution, at ev 22 is 81/2 minutes,
    second table it reads ev 22, 81/2 minutes stock solution.
    As Eric Morecambe said I am playing the right notes but not necessarily in the right order
  14. Andrew Flannigan
    They're not. The upper sheet is marked "3 of 6" and the lower is marked "5 of 9"
  15. Stephen Rundle
    Ok I should have said BOTH are from Ilford
  16. Stephen Rundle
    THANKS ALL.
    At LAST.
    I finally decided, ok, split a 24 roll into 3 pieces, 7.5, 9 and 10.5 minutes
    Here is NINE minutes, I am happy
  17. GeoffR
    The direct answer to the question is, yes it is you.
    You are misreading the tables both give the same development times at Stock, 1+1 and 1+3 for the same ISO it is just that one runs the table top to bottom and the other left to right.
    Thus
    50 ISO stock 6" 30" 1+1 8' 1+3 17'
    125 stock 8' 1+1 11' 1+3 20'
    200 stock 10' 1+1 15' 1+3 not recommended
    Both tables give the same values for the same ISO and dilution.
    Stephen Rundle likes this.
  18. Stephen Rundle
    Perhaps but it is not very clear
  19. GeoffR
    It certainly isn't clever to run the tables in different directions.
  20. PeteRob
    I agree. The first time around I just assumed that there was a misprint. The second time round I read the data sheets and saw there wasn't.
