Hi! I have just brought a Sigma 105mm F2.8 EX DG OS HSM Macro lens and I have 2 questions as I have never used a macro lens before. 1. What is the difference between OS 1 and 2? 2. Can someone explain what these mean…...Full – 0.45m – 0.312/0.45m Thank you for your help.
1)OS1 corrects for all lens shake, OS2 for vertical movement only. 2)it's the focussing distance range. Set on 0.312-0.45m means the lens wont hunt for focus outside this distance.
What he said. Lens based image stabilised systems have either 1, 2 or 3 modes. Mode 1 stabilises the lens to up/down and left/right movement. Because some people like to follow movement by panning, and panning is usually left/right, mode 2 disables this stabilisation so that the IS isn’t fighting the panning movement. Mode 3 is very recent - it is the same as mode 1 but IS only activates when the shutter is released and not on the half-pressure used for focussing. It is common to be able to preset the focussing range for macro and for telephoto lenses. Both type of lenses work with shallow depth of field and the focussing mechanism is low geared to allow very small focus adjustments to be made. If the lens “hunts” for focus it takes an age to wind through the focus range. Therefore a switch on the side of the lens limits the movement. It is important to check the position of the switch before using the lens because there is nothing so frustrating as finding that you cannot focus on what you want to because the switch is in the wrong position.
See the instructions https://www.sigma-imaging-uk.com/wp-content/uploads/2018/04/105mm-F2.8-EX-DG-OS-HSM_manual.pdf
Depends on the camera/lens combination - these days, with some equipment, stabilisation will not activate if the vibration is below a certain threshold - but certainly turning it off will avoid any problem.
Ah - well then - excellent advice though I'd not heard of the motors burning out before. I'll have to look up the manual for my macro lens if ever I get around to buying a geared head and focussing rail for the tripod.
