I used the "Upload a File" option but instead of posting the photo, it was a thumbnail. I will have to work on this
There's an option to insert as full image somewhere at the bottom of the upload screen - scroll to the bottom?
It's a great shot, and almost monochrome - only shades of blue plus black and white. I don't expect any beginner's questions from you!
Thank you for the lovely comments Chester. I took it during lock down and was very fortunate to have that perfect sky
I think my comment should not have the word 'almost'. Your image is truly monochrome because it is all shades of one colour and very unusual because of this. Time for a large print to frame and put on a wall?
Sorry Chester, I have been away and only just seen your post. I have seen a frame with a mount for three or four photos and I am thinking of using it for this photo and a couple of others I took on the same day.
If buying a frame in which you will fit the print yourself, be careful if the print will be in contact with the glass. If this is the case, do not get a glossy print because a single bit of dust between the glass and the gloss surface will case a 'Newton's rings' effect where air is trapped around the dust. Go for a textured or semi-matt finish on the print to avoid this problem.
