Habits and Foibles
Discussion in 'The Lounge' started by Derek W, May 12, 2021.
  1. Derek W
    Derek W Well-Known Member
    I was just wondering if you guys had any habits or foibles?
    One thing I do is every time I finish using the washing machine is I will wipe down and dry the door and seal.
    After using the loo I will always make sure the lid/seat is closed.
    Another kind of foible I have is to close all the doors in my home.
    So what habits or foibles do you have?
  2. spinno
    I frequent the AP forum
  3. WillieJ
    WillieJ Well-Known Member
    I smoked for nearly 30 years. :(
    Catriona likes this.
  4. LesleySM
    LesleySM Well-Known Member
    I cannot bear to see an electric socket switched on if there is no plug in it. My dad was convinced it was dangerous and his obsession rubbed off on me
    Derek W, dangie and Catriona like this.
  5. Andrew Flannigan
    If you use an ultraviolet lamp in total darkness you can see the electricity trickling out of a switched on socket without a plug in it...
    ...honest! :D :D :D
    ascu75 likes this.
  6. SXH
    SXH Well-Known Member
    So when does a habit/foible become OCD?
    And should I be worried about always making sure that anything that can be turned off is when I leave the flat?
    Derek W and Catriona like this.
  7. Catriona
    Catriona Well-Known Member
    Beat me to it. Also when I go to bed. I check all the electrical outlets and turn off those I can.
  8. DaveM399
    DaveM399 Well-Known Member
    Are you sure it wasn’t to stop the electricity leaking out onto the floor?
    Zou and ascu75 like this.
  9. Catriona
    I have found electricians are the worst offenders.
  10. dream_police
    I hate it when someone switches the plug off at the wall. I plug something in, turn the appliance on and then wonder why it isn't working. Curse a bit, then realise someone had previously turned the switch off. Grrrr
    Geren and ascu75 like this.
  11. Catriona
    I think I got a switch-off compulsion ever since my brother (such a nice boy) told me (a kid) to pull a plug out of a socket in the kitchen. My little fingers curled around the plug as it came out - and I ended up against the opposite wall.
  12. beatnik69
    beatnik69 Well-Known Member
    I rub satin labels. As a baby I had a blanket with a satin strip along the top, which I would rub until I fell asleep. Ever since then I've rubbed satin. If you ever see me with my hand down the back of my shirt you will know what I'm doing.
    Zou and Geren like this.
  13. WillieJ
    When a) It is someone else that does it, plus b) it starts to piss you off.
    Glad to have cleared that up. :D
    John Farrell, SXH and Learning like this.
  14. WillieJ
    As long as you stick to your own shirt you should be OK.
    Zou and Derek W like this.
  15. Derek W
    I smoked for nearly 30 years, for roughly 25 of those years I smoked between 40 to 50 cigarettes a day.
    I gave up cold turkey 11 years ago
  16. WillieJ
    I was only 20 a day but after several failed attempts I stopped 17 years ago.
    "Cold Turkey" but I doubt if I would have managed it without the Allen Carr book "The Easy Way to Stop Smoking" which I would unhesitantly recommend to any nicotine user - regardless of whether or not they wish to stop. Without it I rather doubt if I would still be here.
    Derek W likes this.
  17. beatnik69
    umm... :oops:
    WillieJ and Zou like this.
  18. steveandthedogs
    Growing old, though I doubt I'll be able to break the habit.
    S
  19. SXH
    Yep, me too. :oops:
    In my case, I think it dates to the time I went out for a couple of hours and had left the oven on and slightly open. When I got back, the flat was tropical!
  20. Learning
    You will do so eventually. So will I. So will everybody.
