Fuji S7000 memory question
Discussion in 'Fujifilm Cameras' started by thedudeabides, Jul 24, 2005.
  1. thedudeabides
    thedudeabides Active Member
    What is the largest Compact Flash card that can be used with the S7000?
    Is the S7000 compatible with the faster Compact Flash cards?
    Many thanks
  2. FujiSigmaNolta
    Hi there!!
    Since the S7000 is basically an S20pro with more pixels and a different sensor, I would say the most is a 2GB. You can put in bigger cards but only 2GB will be seen as both cameras are FAT16 not FAT32.
    Regards,
    Provia_fan
