Fuji Adaptor ring...can you help
Discussion in 'Fujifilm Cameras' started by thedudeabides, Jul 27, 2005.
  1. thedudeabides
    thedudeabides Active Member
    I have bought the Fuji adaptor ring for the S7000. I want to keep dust out of the tube went its not being used.
    Is it possible to buy a cap to go on the end? The diameter is 55mm.
    Many thanks
  2. FujiSigmaNolta
    Hi there!!
    I am not sure but there must be a solution. Go to Jessops, they sell caps of all sizes, but maybe if you just keep a screw in UV or skylight filter you should be fine. Of the same diameter of course!
    Regards,
    Provia_fan
