Duplication of uploaded raw files
Discussion in 'Computer Related Help & Discussion' started by swanseadave, Jun 25, 2020.
  1. swanseadave
    swanseadave Well-Known Member
    I`ve been editing the raw files for 2019 Lake Como holiday photos and when I reached August 30th I found that
    all the .ARW files for that date have uploaded twice.Why would that happen?All were in separate folders on the CF card,one folder per day.
    Can anyone come up with an explanation why this might have happened?I`m baffled.
    Nine times out of ten it is finger trouble. Do you mean you uploaded them somewhere or do you mean downloaded to a computer? The second set must have something appended to the file_name (_2 or _copy_2 or something similar) which will make them easy to select and delete.
  3. Stephen Rundle
    Occasionally I have right clicked a group and inadvertently created duplicates
  4. swanseadave
    Pete,it happened while uploading to PC from Bridge.I was not aware at the time,only since processing in CS4.
    All of the several duplicates have a different file number leading at first to thinking I had duplicated the shots.I then noticed they were exact copies,except the file number.
    The plot thickens.
    Stephen,I always upload directly from Bridge,usually making coffee at the same time.
  5. RogerMac
    If they have distinct file nos it probably happened in camera and at the moment the shutter button was pressed. Is the camera under warranty?
  6. Andrew Flannigan
    Stupid question: was the camera set to multi-shot? I've put my A65 into that mode unintentionally in the past.
  7. PeteRob
    If the file numbers are different and in sequence then you took more than one exposure. Having the camera in burst mode (multi-shot) is the simplest explanation though I would have thought you would have noticed at the time.
  8. swanseadave
    "If they have distinct file nos it probably happened in camera and at the moment the shutter button was pressed. Is the camera under warranty?"
    No Roger,it`s a Sony Alpha 350 10-12 years old.I bought it with a very low shutter count.
    "If the file numbers are different and in sequence then you took more than one exposure. Having the camera in burst mode (multi-shot) is the simplest explanation though I would have thought you would have noticed at the time."
    Thanks Pete.I actually never use burst mode.I took 20 shots that day,which is immediately followed by another 20 which are exact duplicates except for the file number,which makes 40 shots.
    I always have the camera set for YYYY/MONTH/DATE followed be a four digit number.Why would the memory card show 20 exposures I did not make?
    It was extremely hot that day,in the mid 30s.Could that be a factor?It`s behaved perfectly ever since.
  9. PeteRob
    Has it got 2 card slots and an option to make a back up copy?
    Edit: I've never turned this feature on on my cameras. I have 3 that can do this.
  10. swanseadave
    No Pete just the one CF slot
