Does Anyone Know of Camera Repair Shops in Fife, Scotland?
Discussion in 'Help Team' started by Mawkguc, Feb 10, 2020.
  1. Mawkguc
    Mawkguc Member
    Hi,
    I have a Panasonic Lumix - DMC-FS10 with Sytem Error Focus. The lens will not retract. I am told this a common fault. So i would like to get it fixed.
  2. nimbus
    CEX sell these for £15 in working condition, to be honest it's not worth fixing, just buy another camera.
  3. Catriona
    Catriona Well-Known Member
    Bang it on a table on the base. Sometimes that will dislodge a piece of grit.
    We had similar question recently. Most shops charge to send away a repair so you risk £30 to get the answer that it is broken. I presume Panasonic have an authorised repair centre so you could try asking them if parts are still available. For a 2010 camera of its type it has probably had a good innings. I'd give it a couple of taps as Catriona suggested. If I remember the last post correctly, someone said there was a tendency for some internal gears to get stripped.
    Edit: Can't find the post I am thinking of - must have been another bridge camera
  5. IvorETower
    IvorETower Little Buttercup
    It's a 10 year old design and any repair is likely to be close to the cost of a new, modern equivalent camera. Sad as it may be, if the impact with hard surface fails to get it to work you would do better to buy a new model. As has been suggested, first thing to do should be to call Panasonic UK to see if repairs are still supported with appropriate spare parts. You could always try reputable secondhand dealers if the price of a new camera is truly beyond you
  6. Learning
    This is not an eighteenth century, or like, apple press,for producing juice to make cider; that should be repairable for ever, long after every component has been replaced several times. It is a here today gone tomorrow camera .Like that famous parrot; it is dead
    Panasonic still make very nice cameras and other makes are available.
    Ideally take it to the local recycling centre where it might be treated as electronic waste with salvageable materials, More likely it will go to landfill or an incinerator. That is of no fault of yours. If you do your bit , then you've done your bit.
  7. nimbus
    It's a far from uncommon occurrence on many cameras with similar types of lens, an inherent fault of cheap mass-production.
