Cleaning a camera ?
Discussion in 'General Equipment Chat & Advice' started by Stephen Rundle, Jul 6, 2020.
  1. Stephen Rundle
    As you know ! I have bought a D60 lately and have just ordered a D30 Canon.
    However it is in a mess. Image from ebay seller
    Whilst I am not bothered too much it would be nice to use it, so, what would you clean the mirror with and how, thanks
  2. Stephen Rundle
    I do have these anything else I need
  3. GeoffR
    Those will do to start,
    Don't touch the mirror, with anything.
    You may want a brush, a modellers paint brush should suffice to shift dust that can't be blown out.
    A 1/2" paint brush cut to about 1/2' long can be used with a solution of washing up liquid and water to shift grease from the outside, you don't need much, just moisten the bristles and gently scrub the outside. A tooth brush will do just as well.
    A lint free cloth moistened with Isopropyl alcohol is good for shifting greasy marks from screens and lens mounts, though that one doesn't look bad.
    You may want to have a clean cloth on the surface you are working on and a towel to dry the outside once it is clean, you aren't getting it wet but you will want to remove any water that remains.
    Stephen Rundle likes this.
    Best not to touch the mirror. Too easily damaged
  5. Stephen Rundle
    Will have to
  6. GeoffR
    I suggest that you won't have to. If it won't come off the mirror with a blower you need a professional clean of the mirror. SLR mirrors are "front silvered" and the surface is very soft and easily scratched, by which I mean so easily scratched that even a soft cloth can leave permanent damage.
  7. Stephen Rundle
    Not dramatically bothered as it is a D30 but if it is usable ok without then I won't but you know what people like me are like, OCD etc
  8. Craig20264
    Craig20264 Well-Known Member
  9. Stephen Rundle
    I usually post this one :)
  10. Stephen Rundle
    Came today, says on box top left for "monitors" ?? :eek:
  11. cliveva
    cliveva Well-Known Member
    Hi, it looks like the silvering has deteriorated, but difficult to tell from photo. Could you do a closeup of just the mirror, with defused lighting?
  12. PeteRob
    Probably someone trying to clean it. Looks in dreadful state as if it has been stored without a body cap on.
  13. GeoffR
    That it does.
  14. Stephen Rundle
    YOU were RIGHT, when using the camera it does not show, effect it.
    It IS just years of dust
  15. Stephen Rundle
    Thanks all
  16. GeoffR
    That makes a change
  17. IanG1957
    IanG1957 Well-Known Member
    Hear hear
  18. dream_police
    I suppose if you put it in rice, making sure enough goes into the camera all the water will get absorbed and should be OK.
  19. Stephen Rundle
