CF & SD cards which one ?
Discussion in 'Canon Conflab' started by southonline, Jul 21, 2014.
  1. southonline
    southonline Well-Known Member
    I'm looking at getting some memory cards as I've started using my 5D and its eating into my single CF 32GB card
    I've always used Sandisk Extreme in the past and I presume these are still pretty good ? I know cards can fail so I presume getting 32/64MG is the better option than 128MG? I've also used Lexar
    Also is there any difference between CF & SD cards? as I can use either or both - the camera won't be used for video
    Cheers
  2. nimbus
    The only cards that I have had any bother with have been Sandisk, not Ebay fakes either. I have found Lexar and Transcend are both fine.
    There is quite a lot of difference between SDHC and CF cards, I wasn't aware the 5D used SDHC cards. CF tend to be more robust, aside of bending the pins in the camera body if inserted roughly and have faster read/write speeds.
  3. southonline
    yes the 5D takes both - I've never had the option of using SD, hence asking and I was a little concerned as I've never had a CF fail and they do feel a little more robust
    So Transcend, another make into the fold ;o) ...
    I always use Sandisk extreme. In my 1D, which has twin card slots, I have an 8 GB CF and 8 GB SDHC and I only once filled them both in one outing. you can set the camera up to write across the divide. The CF is prime use and the other is backup. I don't keep shots on the cards if I can help it. I suppose though that the 5D file size must be quite big.
    The number of SDxx cards on the market is enormous and quite confusing. I need to get a bigger SDHC and was looking to see what to get. As a replacement camera for my G10, for when the big cameras are too inconvenient to carry, I bought a Fuji E2 this weekend, encouraged not a little by the AP fieldtest report last week. The raw files are 33 MB ! I wasn't quite expecting that from a 16MP camera.
  5. Roger Hicks
    If you can use both, why not use both? I would. What are your pictures worth to you?
    Overall, I've also found SD cards more reliable than CF: I have cameras that use one or the other, but not both.
  6. grove39
    grove39 Well-Known Member
    I've started using Transcend in everything now.
    I stopped using Sandisk when all the fakes started showing up and even Amazon themselves have been caught out by them.
  7. southonline
    I dont have any issues with using either or Roger, my question was which one did people find more reliable - After reading a few postings here it really does seem each has there preference but backing up which is better or not can't be done - So I will stick with buying 32gb cards & have one in each slot should one fail or get full up
    Transcend is a make that comes up often Grove39 - so I'll check them out, cheers
  8. Gezza
    Gezza Well-Known Member
    Ever since getting the 5D3 Ive been using Sandisk extreme pro udma7... their read and write speeds for the larger files are pretty quick. Apparently only the cf slot supports udma and the sd is standard speed (even if you use a fast sd card ) and the camera will default to the slower speed if you have both on board.
  9. 0lybacker
    0lybacker In the Stop Bath
    I usually have a Lexar & a SanDisk in the same size as I upgrade cards as cards increase in size & reduce in cost. Makes identification easy although they can always be numbered. A tel.no. on the card can be a good idea, too.
    It's CF for me as the main camera uses only that and SD where required by others, or XD in Olympuses. CF are easier to handle, imv, and you have a fighting chance of hearing should you drop one, even perhaps on grass - something highly unlikely with the smaller cards. Haven't had a failure yet with a card I have bought new. The only failure so far is with a frozen SanDisk CF that came with a s/h camera. Keep meaning to be cheeky & get the Co. to honour their lifetime guarantee on that one.
    Some photographers with dual slot cameras use both CF & SD and arrange things, camera permitting, so that when shooting RAW & JPEG, one type of file goes to one card.
  10. CHRI5
    CHRI5 Member
    Been using a 32gb transcend cf card for a while, went for a 32gb transcend sd card, I'm going to try and write raw to the CF and JPEG to the SD.
  11. Malcolm_Stewart
    By "5D" in this instance, you must be referring to the 5D III. My 5D & 5D II only take CF cards.
  12. southonline
    yes bought it last week
  13. Malcolm_Stewart
    I hope it performs as well for you as the fanboys say it does. My 5D II is fine for what I use it for, and if the AF on the 5D II is its weak point, I've not noticed it so far - probably because I'd be using a 1D IV instead.
  14. southonline
    I've only taken it out once so far and I've been pleased with the results, however I need to get my head around the AF settings which are vast !
  15. Gaz J
    Gaz J Active Member
    The 5DIII as stated above has a slow, 20MB/S, SD slot. If write speed is what you're after then only use a CF card.
    The 5D3 can utilise UDMA 7 cards and there is a benefit to using the fastest CF cards if you're prepared to pay for them.
    I only use Sandisk CF cards and it is possible to get another 8 frames before the frame rate slows form 6 FPS by using their 160 MB/S card compared with their 60MB/S card.
