Bespoke Camera Cases
Discussion in 'General Equipment Chat & Advice' started by Geoff_s, May 30, 2019.
  1. Geoff_s
    Geoff_s Member
    I am at the stage now where I think I have all the kit I need and I want to be able to keep it all in one place rather than the various boxes and cases that I currently have.
    So, I’m looking for somewhere that can supply something like a flight case or rigid case and are able to custom cut foam to fit all my stuff. I guess there is a possibility that I may acquire more bits so it would be good if it was possible to cut the foam again at later dates.
    Has anyone ever done this or could recommend a way forward?
    Cheers
    Geoff
    Peli cases fit that description but they are for keeping a relatively small outfit safe while travelling rather than storing vast amounts but it depends what you have. My peli cases are about the same size as the hard case for a Canon 500 mm F4. One has a 3 light rotalight kit with stands in it. It is straightforward enough to cut the foam inserts.
  3. Roger_Provins
  4. Geoff_s
    Geoff_s Member
    Thanks Rog. I checked that out and they do the foam inserts. I'll do a bit more investigating on this one. Cheers!
