Bees
Discussion in 'The Lounge' started by swanseadave, Aug 1, 2021.
  1. swanseadave
    swanseadave Well-Known Member
    I`ve discovered this morning that there appears to be a bees`nest in the garden.
    There`s a Nevada shrub rose in one corner with a low stone wall in front of it,
    and underneath is a gap between the low wall and the soil which is at a lower level.There`s been a lot of
    coming and going while I watched.I don`t know what type of bee it is but a few
    years ago we had a few leaf cutter bees in a different spot.
    I`ll keep and eye on them and hopefully get a few shots.I should think my 90mm macro lens should be ok.
    ascu75, Zou and daft_biker like this.
    Don’t risk yourself if it is a honey bee colony. We had a beekeeper on the allotments and one hive lost the queen which makes them tetchy. Bees give a first warning if they feel the colony is threatened. They fly into you, feels like being hit by a pea-shooter.
  3. swanseadave
    Thanks for the warning Pete.I hadn`t intended to get in close for I can see the risk.
    I thought 90mm as a short telephoto keeping well back may yield a few shots.
  4. steveandthedogs
    Could be a swarm?
    S
  5. ascu75
    ascu75 Well-Known Member
    Sound great! :D I love bees and have found them to be photogenic. But in saying that I don’t have one picture taken this year and I ain’t going searching on old hard drives this time of night :eek:
  6. GeoffR
    I take bees with a 70-200 and a 1.7x converter, at the long end!
  7. PeteRob
    Individual bees no problem, they won’t bother you, a 100 mm macro is fine. I’d be more wary of homing in on a nest even with a close focus 340 mm equivalent.
  8. Learning
    Bees and even wasps rarely are trouble unless you bother them. I do suspect however that we might emit pheromones of fear when we are afraid. And bees recognise that they may have an advantage. That is only suspicion, not a fact.
    ascu75 likes this.
  9. ascu75
    Footloose and Learning like this.
  10. Footloose
    Footloose Well-Known Member
    The rooting up of hedges and a reduction in the width of untended borders between the hedge and cultivated land has had an impact. What is people find surprising, (although I don't think they should) is that bees are thriving within towns and cities (probably) as a consequence of increased greening in these areas and the much wider range of different flower plantings.
    Some beekeepers have hives that are moved to different sites such as orchards to pollinate their plantings etc because the bee is far better at doing this than any of the other methods.
    ascu75 likes this.
