Another flashgun question.
Discussion in 'Pentax Chat' started by tazio35, Jan 8, 2008.
  1. tazio35
    tazio35 Well-Known Member
    Didn't want to hijack Monobod's thread...
    I have an ancient flashgun that's not TTL and uses only the central trigger connection. This is a hangover from my old Praktica.
    I think it may have a bit more power than the pop-up flash on my GX-1S and would be further off axis. Is it safe to have a play on my DSLR, or is there some way it might fry the electronics?
  2. El_Sid
    Quite possibly... Some older flashguns designed for purely mechanical camera can have some quite hefty trigger voltages - easily enough to fry an electronics dependent camera. There's a comprehensive list of voltages here, they relate mainly to use on EOS camera but the actual voltages are given.
    Frankly I just wouldn't risk it but if you want to then a Wein Safe-Sync is a wise purchase...
  3. tazio35
    What a fantastic list - it even had my old Practika gun listed! Thanks very much indeed.
    Apparently, the trigger voltage is 222V, so a little too much...
