80-400vr
Discussion in 'Nikon Chat' started by Nig, Jan 29, 2020.
  1. Nig
    Nig Well-Known Member
    Why does this £1900 lens suffer from dust specks when my 9 year old, £350, 70-300vr does not have any,even though it's well used. What is the difference between them?.
    Nig.
    Done_rundleCams likes this.
  2. GeoffR
    The 80-400 VR is rather bigger than your 70-300 VR and thus draws in considerably more air when zooming, consequently it also draws in considerably more dust. Lens "breathing" is inevitable with zooms so completely preventing dust is almost impossible. Why doesn't your 70-300 have any? It probably gathers somewhere other than on the internal glass elements so you don't see it but it is almost certainly there.
  3. nimbus
    I assume you mean within the lens. It happens, they cannot be totally sealed, air is drawn in and out with use, air contains dust, some gets left behind. It has utterly no effect on results anyway. Perhaps this lens draws more air in and out, don't worry about it.
  4. RogerMac
    Early Oly E series cameras had sticky pads in the body to collect any circulating dust. Perhaps it would be fair to ask why a £1,900 lens is not similarly equipped
    Learning likes this.
  5. PeteRob
    Apples and Pears. All sorts can get inside an interchangeable lens camera when the lens is disconnected. I suspect that a telephoto lens that physically extends to change focal length will breathe through a fine brush seal, and that that seal makes an effective filter.
  6. RogerMac
    But the OP is complaining that it doesn't make an effective filter
  7. Done_rundleCams
    In theory, Nig, you're correct, because, in theory, the 80-400 should be weather proofed although I couldn't find any proof via Nikon UK :eek: , Also, if you're
    80-400 is still under warranty, I would say that having it cleaned by Nikon UK would be a good idea :). If, however, it is out of the warranty period, the
    one question I have is: have the dust specks had any effect on your photos? If not and if it were me, I'd say "c'est la vie" and continue shooting :) .... but,
    that's just me and, truth be told, I'm, sometimes, a bit too laissez faire ;)
    Hope it gets resolved.
    jack
  8. IanG1957
    IanG1957 Well-Known Member
    I'm interested to know why you think this is a problem?
    The further forward (away from the camera) the less of a "problem" - closer to the camera and large muck can soften areas of the image. If the muck is really visible at the rear of the lens, you may see this on the images...but also, possibly not...just a softer area.
    The aperture is also a contributing factor - smaller apertures tend to show "dust" or muck much better than wide open...
    So, are you worried because you see a few specks of dust on the front of the lens, or is it really deep Inside?
  9. GeoffR
    I am sure that I don't need to tell you that many a lens has a rear element that protrudes at some focal lengths/focused distances and is well inside the barrel at others. I am at a loss to see how one would provide an effective filter in such circumstances.
    As it happens, most lenses breath through the camera body as the big hole at the back is open to the mirror box, in the case of an SLR, so a deliberate breathing aperture in the body, with an effective filter may well be the best solution. Better to know where the air is coming from, and control it, than not.
