What's stored first, the raw image or the jpeg sidecar file ?
Discussion in 'General Equipment Chat & Advice' started by mediaman, Jan 2, 2019.
  1. Roger Hicks
    Dear Pete,
    This certainly seems extremely likely. I was (like several on here, I think) conflating which file is created first, and which is written first.
  2. El_Sid
    On those occasions when I take JPEGs rather than raw I find that it takes less time to process and save a JPEG than to simply save a raw file. The reason for this I suspect is that the JPEG is only 8 bit rather than 12 or 14 bit and therefore a lot smaller. The write procedure is the rate limiting step as it is far slower than the actual data processing step(s) - the time taken to write a file to is far in excess of the time it takes to actually process the image....
  3. cliveva
    cliveva Well-Known Member
    The RaW is what the Jepeg is created from, and could be saved first, but only the manufacturer could tell you!!!
  4. daft_biker
    daft_biker Action Man!
    Unless someone knows of a debugging tool which can trace the steps..... or copies the firmware off their camera and runs it through a decompiler to generate some hopefully readable source code.
    The manufacturer probably already has is documented somewhere and some techie will know what he/she did but I doubt the customer facing support staff will be able to tell us.
    Andrew Flannigan likes this.
  5. Andrew Flannigan
    ^^^^^^ what Andrew said.
  6. Benchista
    I don't really see why which is saved first matters - it's clear that the RAW files is created first, because that's what a RAW file actually is - a JPEG is always crreated from raw data, even on cameras that can't save RAW files.
