Stabilisation and tripods
Discussion in 'AP Magazine Feedback & Suggestions' started by GeoffR, Jul 29, 2019.
  1. GeoffR
    Interesting Letter or the week in AP dated 3 August. Should you turn image stabilisation off when using a tripod, or not? I have to say that the author was right to ignore the "advice" to turn the stabilisation off, and indeed the comment about graduated filters. However, I would say that one should be guided by the camera and/or lens manufacturer. If the manufacturer says switch off or change mode when using a tripod they have probably done the research to support that advice. I've never used my one VR lens on a tripod so I have no idea what, if any, effect it has but before using it on a tripod I would check with Nikon this is what they say: "When the camera is mounted on a tripod there will be very little, if any movement. If the VR function is turned on when used on a tripod, this may result in a reduction in image quality as the VR system attempts to adjust for any slight vibration which will not normally affect the image."
    There is then a list of lenses that can cope wit having VR switched on when using a tripod.
    As always, if it works for you, get on with it, there is no "right" way to do things.
  2. Benchista
    Quite. The earliest Canon IS lenses came with advice to switch it off on a tripod. More recent lenses are auto-sensing, and turn it off where necessary.
    Of course if something works for someone, even I'd it flies in the face of manufacturers' instructions, then fine.
  3. RogerMac
    Every now and then I forget and leave stabilisation on when using a tripod,I have never noticed any degradation in sharpness. I suspect that in body and lens systems may behave diferently,
  4. Terrywoodenpic
    I have not used my Canon 40D or it s 17-55 F2.8 in years, But if IS was on when it was on a tripod you could actually see the image drift on the screen.
    So there are definitely cameras and lenses where it would be wise to turn the IS off.
    However I usually forget to do so on my Fuji cameras, and it has never been a problem.
    So it is probably best to follow the particular manufacturers advice especially when doing time exposures.
    I think early IS systems suffered from un-corrected Gyroscopic precession.
  5. GeoffR
    Since stabilisation systems, in my limited experience*, use rate of movement not angle of movement precession isn't generally a problem. Precession at a rate sufficient to cause the image to drift would be pretty unacceptable in even a child's toy.
    *45 years in avionics (autopilots included).
  6. PeteRob
    Taking the 70-200 F2.8 L as an example of early Canon IS, it would probably shake the tripod if left on. It is impressively noisy in action, I think it makes use of the mass of the photographer in keeping the lens elements still.
  7. Terrywoodenpic
    nevertheless visible drift does occur... what ever the cause.
  8. GeoffR
    I'm not suggesting that it doesn't, and I would be intrigued to know why it happens.
  9. Andrew Flannigan
    What I've heard of elsewhere (but not been able to duplicate myself) is a form of self-induced vibration where the stabiliser hunts, inducing vibration in the body, which it then picks up and attempts to compensate for. This supposedly creates a positive feedback loop that gives you shake on the image.
    Drifting is something new on me.
  10. dangie
    dangie Senior Knobhead
    Setting the 2 second self timer on Pentax cameras when mounting the camera on a tripod automatically switches off stabilisation.
  11. Chester AP
    On my K-5 it also raises the mirror immediately, to reduce the risk of vibration from its movement remaining when the shutter fires two seconds later. I use this setting with a cable release for long exposure tripod shots.
  12. Bazarchie
    Bazarchie Well-Known Member
    Totally agree. Depends on the age of the lens and what the manufacturer recommends. Newer lens detect a tripod, older ones do not. Even if the recommendation is to turn off IS, in say windy conditions or with a lightweight tripod, leaving IS on may be beneficial. Whatever works for you is best .
