Processing out of date C41 film
Discussion in 'Everything Film' started by John King, Mar 18, 2012.
  1. John King
    John King Well-Known Member
    I have been asked to process an out of date 35mm C41 film. The actual age is anything between 15 and 20 years old, possibly more. It has only just been found in an old camera after the owner died, and that was 5 years ago! Developing the film does not present any problems with regard to the actual process.
    The present owner is fully aware that nothing may be recovereble but I would like to give it my best shot. Are there any hints about processing times, do it as monochrome using ID11 or what. My normal C41 time is 3mins 15 secs.
    Thanks in anticipation
  2. nimbus
    Since it is a C41 film, would it not be better processed as such? What is recoverable will partly depend on the storage conditions, if it has been in a loft it is likely that it will have deteriorated to a large extent, on the other hand if it has been kept in an unheated environment deterioration may not be too severe, C41 films are fairly tolerant.
  3. John King
    Thanks.
    I have been advised the results are not always the same from identicle film even stored in a similar environment. I have been given times for a +1 push processing which will give the contrast a boost without increasing the fog levels over dramatically. We shall see soon 'cos I will be doing it tomorrow.
    It had been stored inside the camers which itself was in a cupboard so the temp, although not cool should have been stable. I can but try.
    Thaks for your input anyway
  4. John King
    I processed the film yesterday and the film was devoid of any images. It was dark green all over and even the edge markings had gone. Ah well some you win some you don't.
  5. P_Stoddart
    P_Stoddart Well-Known Member
    That is a shame. No edge markings does mean a total failure of cause. What brand of C41 was it by the way. Might be useful to other with overdue film floating around.
  6. PeteE
    PeteE Well-Known Member
    I have processed some 1987 Kodak VPS III I was given successfully -- I downrated it to 40 ASA instead of 160 ASA and gave it 3 mins 40 secs C41 development and got some good negs !! If yours were all 'Green' that means the film has been subjected to some FUMES -- it happens with Ilford XP2 Super, the Chromogenic C41 film -- instead of brown images they come out greenish.
  7. John King
    The cassette was branded 'Bonusprint' so the origin could be anything from 3M to Agfa to early Fuji.
    There was only one cassette so it is not likely will not be repeated any time in the future.
  8. AJUK
    AJUK Well-Known Member
    I recently had a film processed at a standard consumer lab (ASDA) that was over 18 years old, the film had not been stored very well and may have spend time in a hot attic, it came out just fine.
