Printer for occasional A4 printing...
Discussion in 'Digital Image Editing & Printing' started by Aspadora, Oct 10, 2019.
  1. Aspadora
    Aspadora Well-Known Member
    Hi,
    My photography club does a monthly competition, which means I will need to start printing my photos. I used an online printing service last time, which cost £11 for around 10 photos + delivery.
    If I do this every month, will it be worth investing in a printer instead? if so, does anybody have any recommendations?
    TechRadar recommends HP Envy 5010, which is one of the cheaper options they suggest. Any experiences of this printer? Reviews look ok, except for connectivity which I can cope with I think...
    You won't really save money by home printing unless you do a lot of big prints, and continue doing so. Home printing on a photo-printer, rather than an office printer, is mainly a choice because it's a pleasure to see the print formed even if not as magical an experience as mono-work in the darkroom.
    I've got an old A3+ Canon printer that takes 10 pigment inks. Takes £100+ to fill it. If I don't print regularly - which is most often the case - it will eat most of that cleaning itself.
    I have an HP all-in-one office printer that is in continuous use and is wonderful, but I wouldn't use it for photos. I doubt a decent paper would go through the paper path.
  3. beatnik69
    beatnik69 Well-Known Member
  4. Aspadora
    Thanks both! I had no idea the ink cartridges cost so much to replace :eek:
    I'm not all that bothered about watching them print, or at least the novelty will wear off very quickly for me.. so I think i'll just stick with ordering them online. It sounds easier and much cheaper for what I want it for.
  5. PeteRob
    It's all about getting back to that "did it work?" feeling :).
    All inks are expensive. I just replaced the 2 cartridges in my mother's bog-standard HP all-in-one and that was £50. If you get an A2 printer (i'd love one) an ink refill can be £600 or more - they need to be run continuously to be cost effective but the unit cost per print does decrease.
  6. dangie
    dangie Senior Knobhead
    You asked for an A4 printer.
    I've got a Canon IP7250, about £50 from Argos. Excellent print quality from five ink cartridges. When they ran out if I'd bought genuine Canon inks it would have cost more than the printer. So I shopped around and bought three sets of the five cartridges (15 cartridges in total) from 7dayshop for £16. Not really much to loose. If they weren't any good I'd just buy a new printer with ink included.
    The results are excellent. Far better than I expected. I haven't compared the same image printed with Canon ink against 7dayshop ink but I'm quite satisfied with the results.
    beatnik69 likes this.
  7. nimbus
    I have one of these, bought from John Lewis as a customer return, very happy with it, the optional XL cartridges are worth buying. I paid under £50 for it! I was told there would be no ink in the printer, there was a full set of virtually full cartridges.
    My experiences with printers only cover Canon and Epson, I would not buy another Epson, very expensive ink, as opposed to just expensive and heavy consumption, huge amounts being used on start up.
  8. PeteRob
    When I was looking (2008) the printer recommendations I had were all for Canon. Availability of third party inks is wider for dye than for pigment inks and wider for Epson than Canon. I chose a pigment ink printer but these days dye inks are effectively permanent too.
  9. Petrochemist
    Try the Aldi printing service. IIRC You can get A4 prints for ~34p + postage is £2 for as many A4 prints as you want.
    When I printed my own, infrequent use meant I frequently had blocked heads. The last time more than an entire set of cartridges where used up trying in vain to unblock 2 of the black nozzles.
    Aspadora likes this.
  10. Aspadora
    Thanks for the Canon recommendations, i think if I'm going to get one that sounds like a good option.
    Although, Petrochemist has just halved the cost of my print orders so I'm thinking I will go with that for a while... if i find that I'm printing more and more then i may look at buying again!
  11. PeteRob
    But never look at home printing as the cheaper option unless you are churning out A4 or larger. For enprints it will always be expensive.
