Portmuck Waves 2
Discussion in 'Appraisal Gallery' started by beatnik69, Oct 6, 2018.
  1. beatnik69
    beatnik69 Well-Known Member
    I took this one this morning. The tide was too high for the shot I had in mind, so I took this instead. There wasn't really much colour in the sky at all as the sun came up, which was a little disappointing.
    [​IMG]Portmuck Waves 2 by Gary Robinson Photography, on Flickr
    Andrew Flannigan likes this.
  2. EightBitTony
    Not sure the composition excites me to be entirely open. Also, it feels very blue? I actually prefer the shot in black and white (which isn't something I say often about landscapes).
  3. RovingMike
    I think the bottom half is doing nice things, but top half is very ordinary. Mag in the sky again too.
  4. beatnik69
    The sooner I get a decent set of grad filters the better.
  5. RovingMike
    Don't get Cokin. Ned to pay quite a lot for real ND.
  6. beatnik69
    I used to have Cokin, but lost the wallet a few months ago. Bought some cheapies to tide me over until I can get a decent set but they really are nasty. I'm thinking of going for NiSi. They seem to get good reviews.
  7. Craig20264
    Craig20264 Well-Known Member
    Cokin aren't bad until you start doubling them up, then you get a magenta cast, but as Mike says, a true neutral density filter is expensive. I bit the bullet and have been slowly replacing my Cokins with Lee. If you're serious about landscape photography, it's a shame to put a piece of inferior glass in front of an expensive lens.
    A cheaper method is taking a couple of shots and blending the two exposures. ;)
  8. RovingMike
    I'd go with Lee.
  9. alfbranch
    alfbranch Well-Known Member
    Cokin Nuances are very good indeed
    Gary
    This is a much better shutter speed than the 3 seconds in #1 get out for a bigger sea and play with shutter speeds from 1/30 to 0.5 seconds and if you get close and avoid waves and spray the irish sea has much to offer
    I live the other side of the Irish sea.
    beatnik69 likes this.
  10. Benchista
    I use Lee, and also find Hitech fine (I currently use one of their reverse grass, and have a set of P size grads) , but if I were buying now, I would get Nisi or Breakthrough filters, which seem excellent.
    Incidentally, I'm building up a set of old Cokin A filters for a little project I have in mind for next year - as many weird ones as I can find.;)
  11. beatnik69
    I've been looking at the NiSi ones. They come with a CP and the filter holder has a little wheel built in which allows you to turn the polariser without rotating the rest of the filters.
  12. Benchista
    And the NDs are optical glass, and have a good reputation for lack of colour cast. Breakthrough are allegedly the best of all, but expensive, and only available from the US, as far as I can tell.
  13. PeteRob
    I finally got around to buying some Lee Filters. The main downside is the amount of space their pouches take up - this was a big surprise to me. I wrote off my Cokin ones by trying to save space by doubling up in the carry boxes - an excellent way to make ND ground glass I found.
  14. swanseadave
    swanseadave Well-Known Member
    Am I the only one seeing two ships on the horizon just right of centre?
    I don`t see magenta in the sky either.My monitor is calibrated, too before anyone asks.
  15. PeteRob
    No, they are there. It is more a hint of magenta. It isn't particularly obvious on my screen.
  16. beatnik69
    It's actually two lighthouses on a pair of islands called The Maidens. In between them you can see a bit of Scotland (Kintyre)
  17. RovingMike
    Fairly clear on mine, re-calibrated today. This is without:
    But some seems to be creeping back in between flickr and here.
  18. PeteRob
    I can see it if I toggle between the two, more clear on my NEC than my iMac screen.
