Poll - Have you ever shot water at long exposures?
Discussion in 'Weekly Poll' started by Liam Clifford, Sep 13, 2016.
  1. Liam Clifford
    Liam Clifford Active Member
    This week's question is: Do you shoot long exposure water shots? Cast your vote today.
  2. spinno
    Not yet...well I have but only briefly hand held which didn't quite work but gave me an idea of what was needed.
    Not sure that milky water works in every case
  3. Fishboy
    Fishboy Well-Known Member
    Yes, I've taken long exposure shots of water - principally to see whether I could master the technique.
    I like the effect of long exposure photography, however I'm very aware that such images are now considered to be something of a cliche so, unless I manage to achieve a spectacular result, I can't see any of them ever being subjected to the scrutiny of anybody other than myself.
    Cheers, Jeff
    PS - none of the possible answers were applicable.
  4. RogerMac
    Only once and that was at an AP masterclass, I have not used it otherwise as I normally do not carry a tripod. I must try harder.
  5. El_Sid
    Not in the 10 stop ND sense of the concept but I have done longish exposures in low light conditions...
  6. PeteRob
    No. Moving water has a liveliness thst needs to be captured. I can understand averaging out waves etc. for sea scenes but running water -no.
    Wheelu likes this.
  7. daft_biker
    daft_biker Action Man!
    Yes, and I'll do it again too!
    I don't think there is any harm in practicing technique whether for the sake of learning or art. I've learned things from trying it and have seen others produce stunning shots so it's fine by me.
    JennyTog likes this.
  8. JennyTog
    JennyTog Member
    Yes, with the Lee 10 stop filter and others. I really like the results :)
  9. GeoffR
    What he said!
  10. Trannifan
    Trannifan Well-Known Member
    Now and again to assess the effect.
  11. SXH
    SXH Well-Known Member
    Never, the idea has never interested me.
    So, no option on the list for me. Again. :(
  12. Terrywoodenpic
    No. but I would if the right subject came up.
  13. AlexMonro
    AlexMonro Old Grand Part Deux
    Unfortunately, there was no poll option for my position.
    Yes, I have shot moving water at long exposures, but only a few times. Generally I don't particularly like the effect - it doesn't "look right" to me.
  14. Ffolrord
    Ffolrord Well-Known Member
    Yep. I don't give a monkey's if people think they are a cliche.
  15. Terrywoodenpic
    In this context what is a long exposure?
    I have shot streams at about 1/10 to 1/30 second which only partial stops the water.
    I have also shot spray at 1/000 second which only just about stops the droplets.
    All theses shutter speeds are on the long side compared to what I might use to stop these actions completely.
  16. Zou
    Yes. 10 stop ND and remote control bought mostly for this purpose.
    PeatSmoke and JennyTog like this.
  17. CharlieJ
    CharlieJ Member
    Like Terrywoodenpic I have shot streams at around 1/15 second. I find that this captures the movement of the water but retains enough definition that it still looks "natural".
    As for really long exposures... for waterfalls I don't like the effect at all because I feel it robs them of their vitality, but for the sea I like the surreal effect when a long exposure is used in conjunction with man-made structures.
    Craig20264 likes this.
  18. 0lybacker
    0lybacker In the Stop Bath
    One of the interesting things to do - now at low cost (just time! ;)) on digital - is to run through a whole range of shutter speeds. Sometimes the camera will reveal things unseen by the eye and un-imagined by the mind.
    Zou likes this.
  19. Fishboy
    "..things unseen by the eye and un-imagined by the mind"
    Are you talking about ghosts? You are, aren't you? Ghosts!
    Cheers, Jeff
  20. Themis
    Themis Well-Known Member
    Again, none of the options on the poll fit my case. I tried longer exposure than what's required to 'freeze' the movement, but I don't like the milky effect/totally averaged movement, so I only tried a shutter speed slow enough to capture the flow, but also the splashes, something like this: http://www.redbubble.com/people/themis/works/12622880-restless-at-sunset
