Poll - Do you own prime lenses in the same mount...
Discussion in 'Weekly Poll' started by Chrissie_Lay, Feb 9, 2016.
  1. Chrissie_Lay
    Chrissie_Lay AP Editor's PA
    ... with the same focal length but with different maximum apertures?
    Take part and cast your vote on this week's poll - Do you own prime lenses in the same mount with the same focal length but with different maximum apertures?
  2. El_Sid
    Technically the correct answer for me is yes but I don't use them regularly...
    As far as I can remember I only have one set and that's a trio of 135mm teles in Nikon AI - to Nikkors, an aged f3.5, an almost equally aged f2.8, and a Tamron f2.5. The f3.5 I bought dirt cheap and IIRC I was given the other two...
    Hang on - I just remembered I also have two AI fit 50mm Nikkors in f1.8 and f1.4 flavours plus a another 1.8 in AF. In tis case I bought the AF version to replace the manual one as the focus had gotten stiff before picking up the 1.4 for peanuts..
  3. RogerMac
    No. Over the years I have been underwhelmed by the performance of lenses wider than approximately f2 / f1.8 and if one does not want to go wider that that there is not usually a lot of choice.
  4. Benchista
    Yes - and for several systems.
    For EOS, I have 28mm f1.8 and f2.8 IS - they're very different wide open. I also have 50mm f1.4 and f2.5, for which the same applies. For other systems, I've all sorts of things, but for most of them I've at least two different 50mm lenses.
  5. PeteRob
    Nope. Got zooms that have different apertures but I haven't doubled up on primes.
  6. Zou
    No. Different mounts/apertures but no doubling up.
  7. Learning
    Super-Multi-Coated-TAKUMAR 1:1.4 50 and Super-Macro-Takumar 1:4/50.
    Strangely when I looked in the cupboard to verify the exact names of these lenses, I found that it was the macro that was mounted on the old Spotmatic.
    Weren't cameras and lenses very small and light in those days? Such is progress.
    I haven't used that camera for at least 40 years.
    I didn't vote because there was no appropriate response.
  8. nickyr
    nickyr Well-Known Member
    I've got a Nikon 70-200mm f4 and a Tamron 90mm f2.8 Macro, so some doubling up but with justification.
    My only other prime is a Nikon 50mm f1.4 which sits between my 16-35mm f4 and the 70-200.
    I used to use a Nikon 24mm Ai-s manual focus jobby but that is now gone.
  9. steveandthedogs
    When you say "in the same mount", does that include fixed-lens things as well?
  10. Wheelu
    Wheelu Well-Known Member
    Yes, for example Pentax 50mm K fit in f2, f1.7 x3 and f1.4 - crackers really. My 1.4 is no better than the 1.7s and heavier to lug about. Couldn't resist a bargain.
    Likewise Zuiko 50mm f1.8 and f1.4 - and out of all of this collection it's the Zuiko 1.8 that I use on my NEX. It's a star performer.
  11. 0lybacker
    0lybacker In the Stop Bath
    Someone didn't think about those questions too carefully.
    No response again from me.
  12. Roger Hicks
    Quite a lot:
    Leica -- 90/2 Thambar (soft focus), 90/2 Summicron (sharp), 90/3.5 Voigtlander Apo Lanthar (Frances's really -- small and very high quality, much like Frances) + 50mm (several) + 35mm (Voigtlander f/2.5 and f/1.4 Summilux) + 21mm (Voigtlander f/4 and an f/2.8 from another maker)
    Nikon: several 50mm + 2x135mm (f/2.8 Nikkor, f/2.3 Vivitar Series 1), 2x200mm (Nikon f/4 and Vivitar Series 1 f/3) + 2x300mm (non-Nikon f/4 + f/5.6 mirror)
    Pentax: 50/1.4, 50/1,8, 50/4 macro, and 50/2 Russian + 2x135 f/3,5 Pentax and f/1.8 Porst
    Some were historical accidents: they came with cameras or were silly cheap (4 euros for the Pentax macro), bought to try.
  13. Ffolrord
    Ffolrord Well-Known Member
    Sure. I also have lenses in the same mount with the same focal length and the same maximum aperture.
    The joy of old Pentax fit lenses.
