Poll - Do you ever shoot at wide apertures for shallow depth of field?
Discussion in 'Weekly Poll' started by Chrissie_Lay, Jul 26, 2016.
  1. Chrissie_Lay
    Chrissie_Lay AP Editor's PA
    This week's poll question is - Do you ever shoot at wide apertures for shallow depth of field? Please vote here, thank you.
  2. Fishboy
    Fishboy Well-Known Member
    I use the appropriate aperture for the result I'm trying to achieve - or I try to anyway!
    Cheers, Jeff
    Geren, Roger Hicks and RogerMac like this.
  3. Geren
    Geren Well-Known Member
    Yes.
    I put occasionally. However I nearly always use telephoto lenses wide open to keep exposure times low and accept the shallow depth of field.
  5. Terrywoodenpic
    It would be counter productive to use wide apertures when inappropriate.
    some genres like portraiture benefit from the practice, others like architecture more rarely so.
    Mostly the aperture set is in some way a compromise between exposure and depth of field.
    Roger Hicks likes this.
  6. Zou
    Very often, but I rarely shoot wide open. Both my fast lenses benefit from being stopped down a tad.
    Had a play with a Sony FE85/1.4G today which was stunningly sharp wide open. It'd be called gear lust but for the price which was most unattractive.
  7. Marabak
    Marabak Member
    I suppose the answer is that none of my lens are particularly fast, therefore I have to use their widest aperture if I want to do any sort of handholding anyway. Luckily, my style of photography seems quite suited to this (i.e. little landscape or architecture)
  8. Trannifan
    Trannifan Well-Known Member
    If what I have in mind for the picture requires it, then yes.
    Lynn
  9. Roger Hicks
    Dear Lynn,
    Well, yes, exactly. But far too many photographers seem to do it just because they can. Surprisingly many pictures that cry out for front-to-back sharpness are ruined by deliberately shallow depth of field. Others would be merely bad if they were sharp from front to back but are truly awful because of a very shallow depth of field.
  10. DaveS
    DaveS Well-Known Member
    Nah, I shoot everything at f/64 :D
    Seriously though, I use (Try to use) an aperture appropriate to the subject / situation.
  11. daft_biker
    daft_biker Action Man!
    Yup.....and with reverse tilt too sometimes:D
  12. Benchista
    Control over what's sharp and what isn't is one of the most fundamental technical issues facing any photographer - it's what makes photography unique.
  13. Roger Hicks
    Dear Nick,
    Not really.It's even easier for a skilled painter.
  14. Fishboy
    A short list of people who find that controlling whether something is sharp or not is fundamental to their job:
    Surgical instrument manufacturers
    Manufacturers of those 'fizzy shark' lemon sweets that make your face want to turn inside-out
    Designers of stylish suits
    Piano tuners
    Cheers, Jeff
  15. daft_biker
    Shame it tends to go out the window whenever autofocus is used though. Not that I'm anti-AF as I use it too but I can't control DoF with the kind of accuracy I can with a tripod and manual focus.
    I think that fundamental technical issue of controlling what is and isn't sharp is one of the reasons I enjoy macro photography so much and is the only reason I have a TS-E 90mm. On the other hand my 70-200/2.8 IS2 only really gets used for autofocus stuff and is likely to be fairly close to wide open so it doesn't get used for anything too "technical" but I still like it.
  16. CanonGary
    CanonGary Member
    I occasionally do although I prefer to zoom in as much as I can to reduce DOF.
    I only do this as I don't have many fast lenses though.
