Poll - Do you apply sharpening to your images in post production?
Discussion in 'Weekly Poll' started by Chrissie_Lay, Jul 21, 2016.
  1. Chrissie_Lay
    Chrissie_Lay AP Editor's PA
    This week we ask - Do you apply sharpening to your images in post production?
    Cast your vote on the poll.
  2. Fishboy
    Fishboy Well-Known Member
    Yes. And a right mess I make of it most of the time!
    Cheers, Jeff
  3. EightBitTony
    No option for 'I usually use the default for the RAW processor I use, unless a particular image has special needs, or a particular area in the image needs special attention' otherwise known as 'yes, sometimes more than others'.
  4. Dorset_Mike
    Dorset_Mike Grumpy Old Fart
    A minimal amount on most images
  5. PeteRob
    Usually use a standard amount but not high on strength. The example looks a bit contrived to me. I'd bin anything that soft.
  6. El_Sid
    Yes and the amount applied depends on the output format.
    I suspect that sometimes I apply a bit too much and have been making a conscious attempt to reduce the levels used. It also seems that I need to apply less sharpening to Nikon images than Canon - not sure why, different strength AA filters might be the reason. I have noticed that curved and diagonal lines on my D50 are more prone to 'jaggies' than my 20D.
  7. Geren
    Geren Well-Known Member
    I was shown an interesting technique using an alpha channel to create a mask that allows you to sharpen only the edges of things and only those edges that you want. I don't bother sharpening anything until it's ready for print though and never bother for stuff to bung up online.
  8. Zou
    Standard Lightroom settings usually. Very rarely bump it for specific purposes/images as required.
  9. Terrywoodenpic
    I sharpen as part of the raw processing, checking it at 100 %
    I then out put sharpen as necessary.
    I use the Pete Bridgwood method for Fuji raws.
  10. Mark Adams
    Mark Adams Well-Known Member
    It all depends on the photo I take and what equipment I take it on.
    Mark
  11. Stelsher
    Stelsher Well-Known Member
    I sharpen to suit the output, different approach for printing versus putting something on the Web, although as a rule it's on the subtle side.
  12. MJB
    MJB Well-Known Member
    If I feel it needs it. Usually a 'sharpen edges' in PS6, which I then use the 'fade' function to reduce it to the desired level.
