Re: Nikon D200 is here!!!!!!!!!!!!!! Talking of Seal pups... Guess where I'll be on Thursday, that is if the weather stays fine for it.
Re: Nikon D200 is here!!!!!!!!!!!!!! ....the hunting store??? Isnt it somewhere like Donnas nook(???) Graeme
Re: Nikon D200 is here!!!!!!!!!!!!!! Ey, Donna Nook. Lincolnshire. Was there last year as well: "I'm so cute... Don't shoot me, unless it's with your camera"
Re: Nikon D200 is here!!!!!!!!!!!!!! Just noticed....we started out talking about the D200 and ended up being sold a pup! Graeme
...it has been announced I'm interested in your opinions - I have a Nikon 5700 bridge and a canon eos 300 ( just the one lens 28-200 ) - I've been holding off getting a DSLR not knowing to whether to go for Nikon or Canon - also wondering what level of camera to go for - I want a quality body that will last a few years and good lenses which don't cost the earth. Thanks - Zeph
"I want a quality body that will last a few years and good lenses which don't cost the earth.".............................Unfortunately that particular combination is virtually impossible with regard to digital cameras Zephya I know in the case of Canon anyway that if you want the quality optics then you really have to fork out for their "L" grade lenses. Canon do make cheaper alternatives designed specifically for digital cameras but all the reports I've heard suggest that the "L" glass is still vastly superior. That's not to say that the cheaper lenses are in any way bad, just that they're not as good as the L variants. I suppose if you're not too critical then the cheaper alternative would be fine really but I'd avoid the really cheap what I would term "kit" lenses if at all possible as they really are built down to a price and show it in their optical performance. The best advice I can give is get the best lens you can afford and try not to skimp in this vital area as digital cameras really do demand the best possible glass you can afford. BigWill
Zeph: probably the best combination available at present is the Nikon D70s with 18-70mm lens (35mm equivalent = 27-105mm) This would be a good place to start. I have just been preparing images of York for a stock agency with that lens on a Nikon D2X and looking at images at 100% I can confirm that it is a very very good lens indeed. Other lenses could be added in time. Having said that, however, and as this thread is about the imminent Nikon D200 it might be worth waiting for this one, which is probasbly a better build with a few extras on the D70s and with around 75% more pixels. It is to be marketed with the 18-70 as one of the available packages.
Clive do you think the 18-70mm would do as well on the D100? Just checked out prices and it's very cheap, been needing to replace my 24-85 for ages but haven't had the funds for anything so far. Amazing price for the D200 considering how much the D100 first retailed for!
I'm certainly thinking about getting one. Clive, Bjørn's only substantial criticism seems to be distortion - have you found that a problem?
Certainly more than the 17-35, Huw, but that one is only distortion free at around 24mm (as you once informed me). But all is easily corrected by this freebie download 'filter' which is what I have been using for some time for corrections when necessary.
Hello Clive - does it do a better job than the "correction" filter built into CS2. I struggle a bit on occasion with a rectilinear wide angle (the wide end of a Sigma 24-70) which seems to be well corrected in the centre and at the edge, but introduces barrel distortion in areas between the centre and the edge. Using the CS2 correction filter to get rid of this barrel distortion introduces pincushion distortion at the edge of the frame. Often I can find a sensible compromise, but sometimes it defeats me totally.
Try it Chris - I usually do it in small increments until it looks right. I haven't tried PS's programme as this one seems to do it fine. Mine appears in PS when I click on 'filters'.
