Masters of modern portrait photography
Discussion in 'Talking Pictures' started by smedz28, May 3, 2017.
  1. smedz28
    smedz28 Active Member
    Hi all,
    I am looking for inspiration in the field of portrait photography and thought it would be a good idea to have a look at and study the work of a renowned portrait photographer. Can anyone make any recommendations?
    If it helps the kind of portrait work i'm interested in would be mostly studio type portraits and maybe some natural light portraiture. Ideally looking for a few books that study the style and give a deconstruction of their techniques and work methods etc
  2. Roger Hicks
    Do you really want "modern"? The best portraits are often timeless.
    Pro Lighting: Portraits
    from Rotovision shows the lighting plots for quite a few pictures, as does Hollywood Portraits. Armed with those two you should be able to "reverse engineer" the lighting on pretty much any portrait you see.
  3. smedz28
    Well anything that is transferable to digital photography to be honest. I'll take a look at the suggestions you gave but if there are any books you could suggest as well, I like a good book and helps to refer back to and make notes etc
  4. Roger Hicks
    Um... These ARE books.
  5. Geren
    Geren Well-Known Member
    They *are* books. Roger wrote 'em!
  6. smedz28
    My apologies i've not had a chance to check the links until now. I thought they were links to web pages for online tutorials. Sorry :)
  7. smedz28
    Excellent reviews, definitely going to buy these. Thanks
  8. 0lybacker
    0lybacker In the Stop Bath
    I would suggest looking at two, recently deceased, acknowledged portraiture superstars: Jane Bown and Irving Penn. The former used available light (although it may have been artificial depending on time of day) almost exclusively, the latter had an available light capability in one of his studios but also created an artificial light set-up that was designed to mimic soft daylight back in the days of very restrictive low ISO speeds.
    There are new books available on both of these photographers. Highly recommended.
